This is not Good!!!! - Defender Source
Old September 2nd, 2004, 01:12 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Changed the oil in my transfer box yesterday.
Found a gear tooth
Further investigation revealed this:-
Luckily this was the only cog affected and the broken tooth found it's way to the bottom of the transfer box without getting involved with any other moving parts
Where's the pic gone
I'll try again!!!
Darn the pic is too big, I'll get right on it. seems things have changed whille I was on holiday
Mike Hammond
Old September 2nd, 2004, 02:36 PM
OH you can just use some glue and stick that tooth back on, if you want to get real fancy put a layer of Duct tape over it.
Old September 2nd, 2004, 03:46 PM
Register the vehicle in Arkansas. They don't care about a missing tooth or two.
Old September 2nd, 2004, 03:58 PM
scrover
Steve Cooper
93 RRC LWB
Yummy - Quality Street reminds me of Xmas
SC
Old September 2nd, 2004, 04:14 PM
So Mike how much is it going to cost for a new gear? What do you think happened? Defective material? Bad bearings?
Old September 2nd, 2004, 04:54 PM
mikeslandrover
Mike Hammond
The gear was 20 years old and doesn't owe me much.
I had a cross drilled gear waiting in the wings 45 from Ashcroft Transmissions.
Which glue would you recomend for a seamless repair?
I presume the duct tape is merely to hold it all in place until the glue has gone off. I can forsee problems if the duct tape stays on
Madrid to Calais in about 24 hours motoring probably didn't help.
It was the tail end of an epic holiday which included following some of this year's Paris - Dakar rally route across the Sahara
Mike Hammond
Good shops in LA to help with 110 engine amylg Defender Technical Discussions 9 July 6th, 2008 12:41 PM
Watching some good Rover porno chrisvonc Misc. Chit-Chat 13 January 10th, 2006 11:25 AM
So where's the pics of some good hard rock action Dave? Mike Hippert Misc. Chit-Chat 0 January 26th, 2005 07:51 AM
Good Vibrations Doug_Paoletti Defender Technical Discussions 6 May 24th, 2004 09:12 PM
Good thing he had the jack! PT94D90 Misc. Chit-Chat 3 October 10th, 2003 02:10 PM
