The woes of a nightmare repair job - Defender Source
Old January 20th, 2005, 12:13 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Nobody else but myself to blame on this one, the head gasket and timing chain swap is taking far longer than expected. I figured 4 days at a good pace were enough.... they weren't, and day 5 the snow hit.
I was SOOOO close to done too, but I guess I mixed up 2 bolts when I was re-attaching the water pump, and snapped one off in the timing cover. EZ-out didn't work, and snapped off inside the bolt. So now, I have the timing cover off again, and down to the machinist I go.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 20th, 2005, 12:21 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
I know the feeling about the snapped bolt. I'm replacing my water pump and the stupid gasket broke for whatever reason, so when I was removing the bolts one decided to break in stayed in the timing and one stripped the threads. So much for following the manual and using a torque wrench
World traveler
Old January 20th, 2005, 12:51 PM
Hans's Avatar
Hans
Hans Haase
Yeah, when I pulled the pump and timing cover off to get the broken bolt fixed, both gaskets broke on me.
Of course, I should have expected something like this. When I was taking the plug wires off, 6 of the 8 had the plug connection still on the spark plugs. Oh well, I was going to put new plug wires in anyways.
-Hans
My oil line fix
Old January 21st, 2005, 11:14 PM
Hans's Avatar
Hans
Hans Haase
Boy, this project just doesn't want to be finished!
Got the timing cover back today, machinist did a good job and even cleaned it up all nice and pretty for me. Too bad the gaskets I had ordered overnight shipping from RoversNorth didn't appear today. Makes it a bit difficult to install it again in the morning. I was really hoping to get the front cover back on before the 14" of snow hits.
Oh well.
-Hans
My oil line fix
Old January 21st, 2005, 11:25 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
Smile
I used to have nightmares about my Rover. I was driving to Dallas and I smelled anitfreeze..It was a really bad dream that involved the words head and gasket; luckily I woke up. Just think of this Hans as a minor setback and very soon the water pump will be all back together (I had issues with the H20 gasket too..It was stuck - Had to peel/scrape it off) and you can play in the snow!! Good Luck!
I bought the diamonds myself so I would not have to say thank you to anyone.
Old January 21st, 2005, 11:43 PM
Hans's Avatar
Hans
Hans Haase
I just wish I never broke that damned bolt off in the timing cover, otherwise I'd have it running again by now.
and we're getting 14" of snow tomorrow that I can't go play in :-(
-Hans
My oil line fix
Old January 23rd, 2005, 10:35 AM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
Hans - How is it coming along?
Old January 23rd, 2005, 10:46 AM
Hans's Avatar
Hans
Hans Haase
Can't put anything together until the gaskets arrive, which I ordered on Thursday from RoverNorth.
I'm SOOOOO glad they said it was in stock, and they promised to have it out that day via overnight shipping.
At least I have the timing cover back from the machinist.
-Jams
My oil line fix
Old January 24th, 2005, 12:07 PM
Hans's Avatar
Hans
Hans Haase
Well, at least I got the parts situation cleared up for now. RN charged me for overnight, but shipped via ground. Should be arriiving any minute now, and already got the shipping charges refunded.
-Hans
My oil line fix
Old January 24th, 2005, 01:08 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
Wink
Hans-
I think it is time that you took my Avatar! Driving a Rover is synonymous with "oh the Drama''!! Well @ least you have not had 4 alternators in 3 months!
Old January 24th, 2005, 05:50 PM
Hans's Avatar
Hans
Hans Haase
4 alternators in 3 months? How did you manage that? At least it's an easy alternator to change, though the price is a bit much.
Right now, I am on schedule to turn the key around 2pm tomorrow. If I can figure out where these 2 support bars go.
-Hans
My oil line fix
Old January 25th, 2005, 10:04 PM
Hans's Avatar
Hans
Hans Haase
Finally. Running, no problems to report yet.
tomorrow, dig it out and clean it up.
-Hans
My oil line fix
Old January 26th, 2005, 03:26 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
-Hans
BAM!! Now go play in the snow!
Old January 26th, 2005, 04:15 PM
Hans's Avatar
Hans
Hans Haase
Running much smoother now, I guess that's what happens when you correct previous owner mistakes such as spark plugs that aren't threaded in all the way.
But man, you do notice the drop in power when you swap from the tin to the composite head gaskets. Though the puffy white exhaust problem is gone now.... which HOPEFULLY means I can pass inspection now. Only remaining issue, it's running a bit hotter now and gauge starts moving up at stoplights.
Tomorrow I'll burp it out again and see what that does. Maybe I'll JB weld the thermal clutch on the fan, lock that sucker up so it doesn't slip at all.
-Hans
My oil line fix
ht
RECO: Repair Manual for 95 SW reaper99999 Defender Technical Discussions 0 March 5th, 2006 05:07 AM
Corrosion repair ideas mattarm Defender Technical Discussions 6 February 2nd, 2005 10:18 AM
DIY Cam replacement, who's done the job kellymoe Defender Technical Discussions 6 December 17th, 2004 12:37 AM
how to repair hard top crack? chirider Defender Technical Discussions 8 December 14th, 2004 08:11 AM
Speedo repair artm Defender Technical Discussions 3 October 21st, 2004 08:33 PM
