The snow got me thinking - Defender Source
Old February 16th, 2010, 09:02 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
As I was over at my parents house digging them out with a couple of my friends and a snow blower one of my parent's neighbors that loves my truck mentioned to me that I should put a plow on the rover. Well that got me think not about a plow but a snow blower. Either driven off the PTO or one that's got its own engine with remote start and stop. So what do you think possible or totally nuts?
Jimmy Buffett
Old February 16th, 2010, 09:14 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Why not a plow? Or is that nuts?
My son suggested that over the weekend.
-Ren Ching
Old February 16th, 2010, 09:59 AM
Roving Beetle
Doug
Either one will work very well on any Rover if used carefully. A fisher or similar electric over hydraulic 6' or 6.5' plow designed for a Chevy S10/Ford Ranger etc would be perfect and as long as you drive easy will not hurt a thing. Obviously you will need custom push plates made up but it would be pretty simple.
I am considering putting one on my D1 so I don't have to use my spotless '61 international in the winter months.
Old February 16th, 2010, 10:24 AM
flippedrover
Tyler
'94 D-90
Mostly because I think a snow blower would be more fun. But also my parent's house in Pa has a 1/4 mile driveway that drifts snow up to 4-5 feet that I'd have to take care of. The contractor working on the house there got a dozer stuck plowing the thing and had to be pulled out by one of the farmers. And no I don't know how you get a dozer stuck pushing snow.
Jimmy Buffett
Old February 16th, 2010, 10:43 AM
You'll be the man............ every 10-15 years anyway
Old February 16th, 2010, 11:06 AM
There was a western or fisher factory set up for a plow on a D90. Saw it advertised circa 1994/95. I have only seen ONE NAS D90 with a plow in my life though.
Old February 16th, 2010, 11:57 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Haven't seen any plows or blowers on any rovers here, but it does look like Kili got a signifigant snow yesterday...
Email is
Same place, new dogs.
Old February 16th, 2010, 01:53 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I think Rovers North sold Sno-Way plows for D90s. I have a Sno-Way on my FZJ80, nice unit for a homeowner.
JL
Old February 16th, 2010, 02:29 PM
Don't recommend a snowblower because you will not be able to see the implement from the driver's seat. Hitting things with a snowblower can do damage to the implement and surroundings (very easy to pick up rocks and asphalt chunks). A regular plow mount fitted with a quick-tach adapter may be the best option as you can use the Bobcat or Woods snowblowers that use the vehicle hydraulics. You can rent these. You will have to fit a 45gpm hydraulic (PTO) pump,a reservoir tank and a and control spool, along with the hoses and quick disconnects. I doubt that any type of snowblower that is rear mounted will be very useful. Better a tractor with a Woods snowblower mounted on the Three Point Hitch. A 70-odd inch wide one will need a 60 hp tractor.
A plow isn't much better from a viewing standpoint, but is far more forgiving of impacts, usually bouncing up and out of the way.
In the short term, probably best to just rent a Bobcat for the duration. Ask for a plow attachment It may cost you $500-750 for a week, but that's about a tenth of what a d-90 sized snowblower and hydraulic system will set you back.
Option C is to contract with a snow removal outfit, which alleviates your equipment maintenance and storage requirements. Likely cheaper in the long run anyway.
Old February 16th, 2010, 02:45 PM
My dad has a big old cub cadet with a international snow blower on it.
Works great.
defender snow cover FS gowyn For Sale - Parts 1 March 8th, 2006 10:48 PM
Snow.... TDI Guy Misc. Chit-Chat 20 February 14th, 2006 08:17 AM
Newb thinking about buying D90-HELP Todds112 Defender Technical Discussions 21 October 26th, 2005 09:26 PM
Are you thinking about a Flexalite 210's? javelinadave Defender Technical Discussions 4 June 16th, 2005 11:50 AM
snow chains and 4x4 Best way. paulb Defender Technical Discussions 14 February 28th, 2005 01:51 PM
» Defender Registry
Blue - now sold
KGH
D90
bneri
Add your Defender
