The Right Stuff--gasket making - Defender Source
Old October 8th, 2016, 04:50 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
When I use The Right Stuff, I have typically gotten the pressurized can. I inevitably don't use the whole can and must the time it clogs up and I tear open the can with a screwdriver by the time I am done unplugging it.
Has anyone had better luck with the non pressurized versions like this 5oz version that goes in a caulking gun? Do they last when you don't use them for 4 or 5 months? https://www.amazon.com/Permatex-9907...t+stuff+gasket
Old October 8th, 2016, 05:07 PM
I use those at work, but they are definitely more cumbersome to use. I use a tube well before it dries up, so I can't speak as to how long it lasts. I wouldn't expect it to last any longer than the pressurised tube.
Old October 8th, 2016, 05:09 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
You do know the clog seals up the can, right?
You're supposed to pull out the clog to let the fresh Stuff out the next time you use it.
Rent my
Old October 8th, 2016, 05:25 PM
Assuming it's not the hardness of a diamond and you can extract it from the tip.
Old October 8th, 2016, 06:47 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
It isn't that it doesn't get hard---it is that when I pull up the plug, 90% of the time, it breaks off down in the bottom of the top (with the angled squirty end unscrewed) and I can't get it to flow even when the top is back on. Like I said, most of the time it clogs and not every time. Maybe I just have poor technique...
gas, ht
4.0 V8 engine parts for sale (starter motor, upper gasket set, lower gasket set) bagocheetohs For Sale - Parts 7 August 11th, 2015 07:12 PM
rear hub gaskets, Right Stuff & seal direction cdb Defender Technical Discussions 4 May 31st, 2009 12:01 PM
rear hub gaskets or Right Stuff cdb Defender Technical Discussions 1 May 30th, 2009 12:23 AM
Valley Gasket/Water Pump--Right Stuff or Hylomar? Grover Defender Technical Discussions 2 October 25th, 2008 05:38 PM
Oil Pan Re-seal- Hylomar or Right Stuff? Grover Defender Technical Discussions 7 October 1st, 2008 02:01 PM
