Temp gauge sender for '97? - Defender Source
Old February 22nd, 2005, 04:10 PM
Chaucer
Will
93 110 | 97 90
Anyone know where the sender is for the stock temperature gauge on a '97?
Old February 22nd, 2005, 04:36 PM
yeah I know next to the fuel rail in the front of the engine, it bolts in going verticaly and there is only 1 wire on it. I can take a pic in a day or so.
Old February 23rd, 2005, 10:55 AM
Chaucer
Will
93 110 | 97 90
That would be cool. I'll look myself, but a picture would be nice too.
Thanks!
Old February 23rd, 2005, 11:03 AM
Gonna have to wait a day or so, I can't get to my 90 right now.
Old February 23rd, 2005, 11:53 PM
Chaucer
Will
93 110 | 97 90
Mike,
Is the connector with one wire the sensor you're talking about? See the second picture Closup.jpg.
The workshop manual says the connector with two wires is the "Engine Coolant Temperature (ECT) Sensor."
Is the two-wire one the workshop manual is talking about for the ECU? Perhaps the one for the gauge is the single-wire one?
Old February 24th, 2005, 12:18 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Easy way to tell, when the engine is up to running temperature..... shut the engine off, disconnect one of them, then turn the key back to "on" (don't start it though) and see if the gauge still registers the same. If you disconnect the gauge sender it should either go to full hot or not move, depending on if it's grounded against something as it's laying there.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 24th, 2005, 07:47 AM
Yup! Thats it! 2 wires ECU, 1 wire gauge.
Temp Sender Location DJ Menasco Defender Technical Discussions 10 August 28th, 2006 01:24 AM
diameter of stock temp gauge naeirie Defender Technical Discussions 2 March 2nd, 2005 06:34 PM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
