Technical - Non-D90 question - Defender Source
Old August 17th, 2013, 12:35 PM
JASEcrest
Jason
'88 Defender 110
I'm sitting at a Firestone to get two new tires and an alignment, as my front two tires were bald on the inside. I just had my 2005 Suburban aligned 13 months ago (30,000 miles). They are telling me that I should have it aligned every 6 - 9 months.
Mechanics: are pulling one over on me? I drove it for 5 years and 140,000 miles before it had its first alignment.
Sorry for the non-Defender question; however, I do not have any mechanic friends to ask.
Old August 17th, 2013, 12:59 PM
You should rotate your tires more often.
The only thing that is adjustable on these trucks it Toe. Camber is set by the swivel balls, Caster is set by the radius arms, bit of which are non adjustable.
-Jeff
he's talking about his suburban ...
Old August 17th, 2013, 02:39 PM
JASEcrest
Jason
'88 Defender 110
oops, details...
-Jeff
Thanks Jeff and Jason. I know there are some Suburban (D90 towers) owners here and thought I should get some additional input.
I agree... Tires need to be rotated more often. 13 months and 30,000... I would have caught this earlier.
I am just curious if all mechanics recommend alignments as often a 6 months. Seems a bit often, especially if it never leaves pavement.
Old August 17th, 2013, 03:44 PM
I have an 04 Yukon xl 2500, and I have not had or needed an alignment until recently. Don't trust the sales pitch. Watch your tires and rotate them more often.
Old August 17th, 2013, 05:54 PM
Torsion bars are sagged which is causing excessive camber on the front tires. Not sure on an 05, but you should be able to crank them up to compensate.
Old August 17th, 2013, 09:10 PM
Tahoeyukonforum.com
Old August 17th, 2013, 09:20 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Depends on how often you take it off road, and how extreme. Not hard to knock it out of alignment hitting a big hole!
Old August 17th, 2013, 09:24 PM
Who the heck wheels a Suburban??
Old August 17th, 2013, 09:26 PM
Diddy.
Old August 17th, 2013, 09:27 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Teenage sons?
Diddy.
As in "P."?
------ Follow up post added August 17th, 2013 09:28 PM ------
Teenage sons?
After a case of Milwaukee's Best.
Old August 18th, 2013, 10:55 AM
Anything with independent suspension should be aligned every 15k miles in my opinion. I would also suggest doing a rotate and balance as well since its cheap.
Old August 18th, 2013, 11:08 AM
jafir's Avatar
jafir
Jafir Elkurd
The Firestone shops near me offer "lifetime" alignment for about $175. It's a little pricey, but you could have them align it every 6 months or every 6 days if you wanted to. With the talk about how LR3's eat tires, I'm tempted to buy it for that as soon as I replace the front lower control arms that I've been driving around with for over a month.
85 D90 differential/half-shaft question Roverlab Defender Technical Discussions 6 December 3rd, 2010 10:27 AM
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
Theoretical Technical Question. PDX Bolt Defender Technical Discussions 5 June 15th, 2010 05:57 PM
financing question on d90 Kerr Defender Technical Discussions 20 May 31st, 2007 10:10 AM
