Tdi on the Road! - Defender Source
Old January 17th, 2005, 08:46 PM
Tdi on the Road!
Well, mine's almost done. I've got it road tested, driveable, and filled up with 27 gallons of diesel. Yeah, there's lots of little stuff left to do (silly things like the dash!) but now its a running, driving project instead of a garage ornament.
Most important thing: Get rid of the V8 Stickers.
Name:	Road Tested.jpg
Old January 17th, 2005, 09:37 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Hey Jim, sounds great that you got it running. If you don't mind me asking, how did you end up wiring the main harness to the engine harness (any detailed info would be great)? It has been so long since I started the swap, I forgot how I had planned to wire everything (spent countless nights thinking about it, only to forget a year later).
How in the world have I spent this much money and still don't have a running vehicle?
Old January 17th, 2005, 10:00 PM
I spent countless hours thinking until I just broke down and bought an AMR5856. I tore out the NAS harness and sold it with the 3.9L.
The NAS rear harness will plug into the 5856 but requires about 3 wires to be rearranged at the plug. I used an AMR4019 for the engine harness. That all works out to about as simple as Rover wiring can be.
Old January 18th, 2005, 09:22 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Jim,
VERY COOL... congratulations.
If you've got any engine compartment pics, I'd love to see them.
Nicholas Orros
Old January 18th, 2005, 09:46 AM
if you buy one of these "kits" with are the wiring harness included or would that be varible on the vendor? I imagine a wiring harness is availible from rover but is costly... planning my TDi swap
Old January 18th, 2005, 10:56 AM
I'm not aware of any 300Tdi swap kits other than the NLA Rovers North one. It allegedly included an adapter harness for the NAS, but I have been unable to either get a part number or confirm the existance of the part.
The main harness was 600 bucks and the engine harness was 250. A bit pricey, but after considering several options, I decided I wanted to end up with something that could be diagnosed and serviced using a factory wiring diagram. I've done frankenstein projects in the past and regretted it since I always forget what I did.
I'll take some more pix.
Old January 18th, 2005, 06:32 PM
Pix:
ID:	2333   Click image for larger version
Old January 19th, 2005, 10:24 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Wink
Originally Posted by JimC
(snip)I've got it road tested, driveable(snip)but now its a running(snip)Most important thing: Get rid of the V8 Stickers.
So...how do you feel "her" now?
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old January 23rd, 2005, 04:29 PM
Driving impressions?
Slow as hell! It was slow with the v8, but now its damn slow. It doesnt bother me one bit, in fact it keeps me from driving as aggressively as I might otherwise
Its alot different than driving a gas motor, and I'm not sure I completely have the hang of it yet.
I'm glad I did it, anyone considering a swap should come take a test drive though, because you'd hate to blow 10k+ and not have it be your thing.
Old January 23rd, 2005, 04:40 PM
where in SC? Do you other folks the the Tdi is weak?
Old January 23rd, 2005, 07:16 PM
I'm in Columbia.
I should be perfectly clear, its not weak, its slow.
You can let the clutch out in second gear without using the gas.
But you're not going to match acceleration with the V8.
Old January 23rd, 2005, 07:33 PM
Tdi Lurker
Big Gord
1971 IIA 88
i guess speed is all what you are used to......i suppose if your used to a V8 it may not be as fast, but i don't know, not having had V8 power to compare with....in my case...i had the 2.5 n/a deisel......so the difference is amazing......i have never had a 110 or 90, that had passing power before......and now it does.........but then deisel power is way different that gasoline power in my opinion....the deisel is wonderful in the range "I" need it...where as the gasoline was much better at higher speed.....and of course i am still in the break-in period as you are Jim.....so that will improve i am sure......now granted my engine is a little different than yours, and i do have a little different gear in the transfer case (1.4), but right now my engine pulls like a freight train (especially) in 3rd and 4th gear, and i am told by people that have this Tdi that the power gets much better with some mileage on it, still these are not V8s and they do take some getting used to..
Old January 23rd, 2005, 10:09 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
"Slow as hell!"
Did you do something wronge? Is there some fuel delivery issue? I will put my Tdi up against any stock rover V8 0-50. Even with the 37's. Somethings not right.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 23rd, 2005, 10:23 PM
"Slow as hell!"
Oh Crap, I put the motor in backwards!
Actually, I think everything is set up properly, but I'm still in my first hundred miles on a new motor - Buck, you started with one that was already broken in didnt you? You also might be running a more aggressive transfer case. I'm using the 1.2.
Plus, this is all a pretty unscientific, seat of the pants analysis. I will admit to not timing or comparing the two, and the truck is has been off the road for 4 months, so I might have forgotten how slow the v8 really was.
It also might have something to do with the fact I've been driving the M6 in the meantime...
Old January 23rd, 2005, 11:48 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Out of all the options, I think installing the engine backwards is the most likely! It could need to break in and I do have the 1.4 t-case. With the 1.2, be sure to get a EGT guage and keep an eye on it!!! I would also check the fuel delivery. I do not know if that pump comes adjusted correctly. When you get it dialed in, you will curse the day the Rover V8 was born!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 24th, 2005, 03:34 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Smile
I'm using the 1.2.
Where did it come from?
1.410 (uhmm...?) should have been fine.
Also,did it come with the EGR?
If so,kill it (unless you're really pollution sensitive)
Sure it may not be as fast as a 4.0 but once you'll get use you'll never regret it.
Welcome "on board" in the meanwhile
P.S.
Do you already write on the Tdi list BTW?
Michele
D90 VNTdi
[O]===[O]
Old January 25th, 2005, 07:46 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mine is new and has plenty of pickup. I have a 1.4 t case and 4.11's though.
Legend in My Own Mind.
Old January 25th, 2005, 08:30 AM
I went out an played around with it yesterday - I think I had just been driving it like a wussy boy.
As long as you give it fuel, its downright peppy. I wasnt fueling it enough enough to really get the RPMs and the boost up. Once the boost kicks in, it really moves out.
I've never really driven a turbo charged vehicle (just a few minutes in an Alpina B7) and the turbo-lag takes a little getting used to. Once you figure out the timing though, its great.
I'm much happier now.
Old January 25th, 2005, 08:40 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
like a wussy boy
I could not find this on my dictionary!
It's a good ol' engine,isn't it?
And no electronic gizmos to worry about
Enjoy it.
Michele
D90 VNTdi
[O]===[O]
Old January 25th, 2005, 08:56 AM
do the Tdi's have a blow off valve?
tdi
Road Trip Report, Defender Sightings chris snell Misc. Chit-Chat 5 December 28th, 2005 03:03 PM
96/97 Passat Wagon TDi pcarey Wanted 7 June 5th, 2004 03:05 AM
