Tdi freeze plugs - Defender Source
Old October 9th, 2014, 08:32 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Tdi freeze plugs
How hard to replace in situ?
I've taken one out for a block heater but never put one in...
what this crappy iphone picture should show is the freez plug weeping coolant---looks like it is corroded?
I know they're not very thick but does every thing on a Rover have to rust/corrode?
The plug is completely seated; it's leaking through the plug.
ID:	104599   Click image for larger version
Rent my
Old October 9th, 2014, 09:08 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Pull it out and install another block heater?
Old October 9th, 2014, 10:28 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Jbweld
Old October 9th, 2014, 10:50 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
8 oz. container of K-Seal (follow the directions).
Old October 10th, 2014, 02:24 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Ummm....no.
JB Weld is a better idea...
Maybe the 2nd block heater is ideal...the 1st one is bone dry.
Rent my
Old October 10th, 2014, 02:30 PM
There are expanding block plugs designed for just such an issue where you cant access to tap one in straight.
Especially usefull where there may be some rust pitting on the block edges.
http://www.oreillyauto.com/site/c/se...0290/C0142.oap
Old October 10th, 2014, 03:01 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Bingo---Uncle Doug FTMFW.
Thanks.
I dont want to pour some sealer shit in the motor when I can clearly find the source of the leak.
Rent my
Old October 10th, 2014, 03:17 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I used jb weld on a truck 7 years ago still no leaks
good luck with your search
Old October 10th, 2014, 03:32 PM
Cool- always nice to win !
Old October 10th, 2014, 04:07 PM
I keep one of those rubber expando plugs in the cubby box for emergencies. That said, I wouldn't consider anything like that to be a permanent fix. The freeze plugs are pretty easy to access, and the manifolds are not hard to remove. I would change it.
Though, maybe after uwharrie...
Old October 10th, 2014, 04:22 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Well, after a quick trip around town... $3.69 for the rubber plugger, and my machine shop guy gave me a plug for free from the parts box.
My original pulled for the heater in the pic.
I'll pop the rubber one for convenience, and eventually plan on replacing it and the middle plug(which will undoubtedly spring a leak next month) in the future.
Rent my
Old October 10th, 2014, 05:32 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I really think Jeff looking for the "lazy ass" way to "jerry-rig" this repair.
Sealant, JB Weld (good luck with adhesion of 2 different expansive metals with an epoxy glue on an external, almost clean, surface), or the old "rubber plug" trick are as you state, are only temporary fixes.
Repairing it properly with a new ERC4996 (my last one was actually purchased at my local LR dealership) is easily done, like you say, removing a few easily accessible manifold bolts.
So by doing the "rubber plug" & then doing the correct job later results in loosing your engine block coolant twice.
Old October 10th, 2014, 06:16 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yes Vitton, considering the money I just spent putting a 300Tdi and ZF in a 21 year old LWB, I just cant justify more than $5.00 at this point in time.
Go back to the Smart car forums.
Who said I'll lose any coolant?
Do they not have buckets where you live?
Rent my
Old October 10th, 2014, 06:32 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
PS Jeff, When you DO get around to fixing it properly, there is no "seated" seat (as you mention in post #1) that the plug sits against when installed, if you push enough the plug will go into the block. The best one can try to obtain is a uniform recessed surface of block material around the newly installed "freeze cup"
I use some Permatex# 2 VERY sparingly around the edge of the new freeze cup, others opt for a completely dry insertion.
Also I can see that with only $5 to spend the K-Seal , even if used properly, was outside of your budget.
------ Follow up post added October 10th, 2014 03:41 PM ------
Jeff, Here's some pictures of Smart 4x4's in action, see if you can spot me
https://www.google.com/search?q=smar...ed=0CAYQ_AUoAQ
Old October 10th, 2014, 07:00 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
10-4
I meant *seated* as in it was in its proper position, but I know what you mean.
How much will that cost me?
Thanks for the link, Viton.
Is that you stepping out of the purple/silver one?
Nice legs if it is...
BTW, I plan on fixing this proper like when I have time...
Rent my
Old October 10th, 2014, 07:25 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
And now for a short training film
You can do this with the engine in place just use a socket & turn you 2lb hammer sideways & tap it.
Old October 10th, 2014, 07:46 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Now Jeff, when you are ready & can't get your LWB warm enough inside in the winter, we can discuss building higher temperature thermostats.
This is an advanced class.
Old October 11th, 2014, 07:47 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Jeff ... call me I think I may have a few spares. I had a hard time getting them to seal properly when I rebuilt my 300.
Old October 11th, 2014, 08:18 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
ha- I left you a message yesterday!
Rent my
Old October 16th, 2014, 07:15 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Zack at RN is sending me a jenyoowhine freeze plug BUT Capt Milks had some in stock!
Old one took 45 mins to carefully extract.
Put the new one in the freezer this morning so it could shrink and it went right in with a smear of the Capt's blue hylomar.
Rent my
tdi
300 Tdi Freeze Plug Part # aosias Defender Technical Discussions 12 February 5th, 2013 09:05 PM
300 Tdi Freeze Plug Capt Milks Wanted 0 August 31st, 2011 09:27 PM
300 TDI needs new glow plugs. Bosch or original Beru? sundogcwolfe Defender Technical Discussions 11 December 17th, 2009 10:36 PM
Non-Dealer Anti-freeze souza Defender Technical Discussions 4 May 15th, 2004 11:22 PM
Anti-freeze in the snow Peter Defender Technical Discussions 8 December 17th, 2003 10:22 AM
