Tdi engine braking - Page 3 - Defender Source
Old August 20th, 2015, 12:00 PM
oilburner's Avatar
oilburner
JL
large pile of parts
We're getting off topic a bit here but a Jacobs is often adjustable through a lo-med-hi switch. Fire trucks aren't very heavy and the transmissions are speced for the weight and the fact that the drivers are trying to get there fast, not row through a 13. They probably would not have a very aggressive engine braking setup.
It also depends a lot on ratios and engine RPM. Because the Jake turns the engine into a big air compressor, it will suck up more HP at higher RPMs, and will offer a greater mechanical advantage in lower gears.
On a heavy-spec truck tractor, or a heavy spec dump that's setup to pull a tagalong, you would be able to use very aggressive jake brake settings - you'd have enough gears to make use of it, low axle ratios, a driver that can float gears on downshift, and enough weight to need it. Running lightly loaded in the hands of a bad operator (or one goofing off) you can skid the drives pretty easily.
JL
engine, tdi
left pull when braking paulb Defender Technical Discussions 19 November 7th, 2017 09:21 PM
Ice braking in Pines Jarek M Trips, Trails and Events 10 January 5th, 2010 09:30 PM
Oil Light When downhill braking Baldewin Defender Technical Discussions 6 September 20th, 2006 10:04 AM
front end 'clunk' when braking.. jaherring Defender Technical Discussions 3 September 29th, 2005 12:04 PM
Non D90 tech question... Wobble while braking. jabber Defender Technical Discussions 5 August 30th, 2005 09:22 PM
