Tdi boost pin - Page 4 - Defender Source
Old October 1st, 2015, 11:53 AM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Hi Guys, so its been a while, any current feedback on these fuel pins?
Already running a VNT.
Regards, Eric
Old October 1st, 2015, 12:01 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I've liked both the ones that BRAB let me use
Old October 7th, 2015, 03:41 PM
Boost Pin for a Land Rover Defender Discovery 200 300 tdi Engine
Old October 7th, 2015, 03:46 PM
87 D110 (Ruby)
love mine - get to "roll coal" sometimes, esp uphill!
Old October 17th, 2015, 10:22 PM
couga861900's Avatar
couga861900
Cougar, WM of Hiram 72
Land Rover Defender 90 2.5td
I brought one almost a year ago but never had the chance to have it installed. Maybe this month I would have it done.
Old March 16th, 2016, 11:50 AM
edh
Ex mod 90
Updates anyone? Longevity issues?
The link with the boost pins for 16 states that they don't ship to the US when trying to order.
Old March 16th, 2016, 03:52 PM
couga861900
Last month I had my pin installed. There's definitely a difference in take off power. I'm not sure about fuel economy as of yet.
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
get it
Old December 20th, 2016, 11:48 AM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
Bringing back an older thread. Anyone have updates on this? I ordered a Timber Trail boost pin last night via their ebay page. It says second gen with harder steel. Tempted to put it in a see how it goes but would love to hear first hand from folks that have done it. Any temperature issues?
Thanks!
Old December 20th, 2016, 11:57 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Anyone in Long Island willing to tune my 200TDI?
Old December 20th, 2016, 11:58 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Brandon could probably help you out. Not that he had exceptionally good luck with his 200 :D
Old December 20th, 2016, 12:04 PM
Naplm00
Matthew
they work great as is or with some fueling increases. watch your EGTs.
its a 15min install with basic hand tools. big flathead scrwdriver and a 10mm wrench.
Had mine for a while now
Old December 20th, 2016, 12:19 PM
FWIW I wouldn't install one of these pins if you do not already have a pyrometer installed.
Old December 20th, 2016, 05:09 PM
Surf90's Avatar
Surf90
C.S.
Can anyone explain the science behind this? Basically it alters the curve at which fuel is added to the turbo and basically can allow too much fuel thus causing a heat issue? Is that correct? Who here has one installed?
Old December 20th, 2016, 06:17 PM
Naplm00
Matthew
ive got one installed. Yes it can increase the timing of when fuel comes into the system based on the boost. If you also increase the fueling by the wheel/star /ect you will run the engine hotter. the EGT gauge that is used to watch the exhaust gas temps can keep you in a safe range.
Even if you dont use a the boost pin and you screw around with the fueling you can run the engine too hot (not the coolant) and melt a piston or have some catastrophic engine damage.
EDIT:
Best course of action: install EGT and boost gauges so you can tune the engine properly, buy a dial indicator to nail the pump timing spot on, install boost pin, adjust fueling to gain performance but use gauges to make sure you are in a safe zone.
Generally over 1350 or 1400 F for an extended period can cause damage. Stock boost on a 200 tdi is 12psi.
A full width intercooler can help lower EGTs and increase performance, a free flowing exhaust can drastically help EGTs
My truck runs down the highway in 70 degree weather at 65 MPH at about 700F. If im climbing a hill hard and long ill get close to 1300. If its cold outside and im going under 55 my EGT will read about 350 degrees.
EGT probe location on my truck is the center of the exhaust manifold directly before the turbo
I have a boost pin 1.2 tcase and a massive 3in turbo back exhaust, pump fueling has been minor tweaked and the timing has been put spot on with a laser brand timing set made just for the 200tdi
Old December 20th, 2016, 10:53 PM
Surf90's Avatar
Surf90
C.S.
Great info! Thank you Matthew! I'm down near San Diego but if I'm ever up near you I want to check out your setup. Thank you!
Old December 21st, 2016, 07:25 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
This video is pretty helpful for using a dial gauge. His other vids are pretty good as well.
boost, tdi
TDI owners.. Show me your Boost and EGT guages josh-man Defender Technical Discussions 59 December 4th, 2014 08:59 PM
300 Tdi Low-End Boost/IP Tuning Jackie Treehorn Defender Technical Discussions 55 August 13th, 2014 07:06 PM
Hella Euro 7 Pin to 4 Pin Trailer Wiring Adapter Wolf Fabrication For Sale - Parts 2 February 28th, 2013 02:57 PM
Boost Lost on 200 TDI Rugbier Defender Technical Discussions 17 August 26th, 2010 05:40 PM
D90 caliper brake pin - cotter pin help Gardrover Defender Technical Discussions 4 May 29th, 2009 02:01 AM
