Tdi boost pin - Page 2 - Defender Source
Old November 11th, 2014, 09:51 PM
I'd be interested in trying one of these out if it does as advertised.
Old November 11th, 2014, 10:01 PM
this is a great find, but curious of it's effect on a 2.8 tgv.
Mark Kellgren
KM4BOR
Old November 12th, 2014, 06:27 AM
BRAB
Brandon
200TDI in a RHD 1986 D90
rrcbyhill@gmail.com
Old November 12th, 2014, 06:42 AM
Dubious. Maybe with a fuel line magnet to help align the atoms tho...
Old November 12th, 2014, 07:14 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I say we wait for one or two board members, those who have ordered it already, and if it's any good we can set up a group buy for those who want to try it also.
Cheers
- Charles Eames
Old November 12th, 2014, 07:50 AM
87 D110 (Ruby)
I am getting one...will record egt and boost prior to and after.
FWIW my boost peaks at roughly 11-12 on the vdo boost gauge. Can't get anymore. Not sure what is standard for everyone with a 200tdi
Old November 12th, 2014, 09:10 AM
thats about it may be 14 on the day it rolled out of the factory. 300's make 16, again not much more but every little bit helps. If you want more you have to get a different turbo.
Old November 12th, 2014, 09:34 AM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
Interested.
Old November 12th, 2014, 01:33 PM
oilburner's Avatar
oilburner
JL
large pile of parts
If you guys want good info for tuning a 300TDI, look at the info online for 1st generation Dodge Cummins turbo diesels. They use the same pump, but with 6 channels and there are good writeups on what each adjustment actually does. There is the full fuel screw, fuel pin, AFC star wheel, as well as timing adjustments. Lots of possibilities. Different adjustments increase fueling at different points as the engine spools up and you can tune to make it perform as you want it to.
Many of the Dodge guys just grind their own fuel pins. The stock fuel pin is usually adjustable by rotating it, the cam profile will vary with the rotation angle, so you may want to mess with that before buying a new pin. You can also get VW TD (1.6) fuel pins, there are many different profiles.
Anyone know the injection timing spec for a 300TDI in degrees BTDC?
JL
Old November 12th, 2014, 01:44 PM
The "point" of these pins is to give a larger range of fueling change with boost than is possible with the stock pin. at stock boost levels, there is probably not much to gain as the stock pin can manage. At higher boost, it is not possible with the stock pin to be correctly fueled on and off boost. This pin helps that.
Timing is not really described in that fashion as the injection happens over a period of time. It is set by the amount of lift of the plunger at TDC. It is 1.54 mm for both the 200 and 300 TDI.
Old November 12th, 2014, 02:02 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Edit:
It would be cool to know what the actual timing spec is. I have looked for it for years and never seen the actual timing number. The timing spec not being in degrees has nothing to do with injection event length, most anything with a Bosch VE pump is timed based on plunger lift, it's the way it is set. Generally there is a corresponding table that relates plunger lift into degrees ( I have such a table for both VW and Cummins applications) but I have never seen one for the 300TDI.
I would bet they are retarded from where they would make full power.
JL
Old November 12th, 2014, 02:40 PM
They seem to be retarded a bit from peak power. There is a fair bit of room for variation with the workshop method of locking pins. Using a dial gauge on the plunger is the best way to go if you want to test.
I'm not sure if anyone has played enough to know the best setting. On the 200TDI (what I have), the vacuum pump is in the way, so it is a pain to check with a dial gauge.
Old November 12th, 2014, 03:40 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I recently bought an electronic pulse adapter to drive a digital timing light, best thing since sliced bread for checking timing. I think that the general hokeyness of the factory timing procedure is why some 300TDIs seem to run well and some are dogs. I'll eventually time one with the digital stuff and see.
JL
Old November 12th, 2014, 04:19 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
These pins would work too but I'd only go with the M2 pin as the rest seem a bit extreme
http://www.mandhinc.net/DPD-1-F.html
I emailed him a while go and he sells them for $110
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 22nd, 2014, 03:32 PM
khalidkassim
Khalid Kassim
1985/Defender
I'm in for the group buy, but can we do it sometime soon?
I'm craving a good power boost on my defender!
Old November 22nd, 2014, 03:51 PM
The position of the IP on a 2.8 also makes using a dial gauge a PITA. I have a gauge and haven't done it yet because of that reason.
Digital solution that is as accurate as dial would be high on my list
Mark Kellgren
KM4BOR
Old November 22nd, 2014, 08:05 PM
87 D110 (Ruby)
Originally Posted by ini88 View Post
These pins would work too but I'd only go with the M2 pin as the rest seem a bit extreme http://www.mandhinc.net/DPD-1-F.html I emailed him a while go and he sells them for $110
Out of stock until January 2015. That is what I was told a couple weeks back.
Old November 22nd, 2014, 08:13 PM
khalidkassim
Khalid Kassim
1985/Defender
More affordable to buy them from the timber trail 4x4 - 55 Gbp = approx. $85
Old November 22nd, 2014, 08:37 PM
As discussed earlier timber trail stole the design and you should not be buying from them.
Old November 22nd, 2014, 09:33 PM
Timber trail doesn't make the pins and sells them for the manufacturer per my exchange with Timber Trail.
Do you information to the contrary John ?
boost, tdi
TDI owners.. Show me your Boost and EGT guages josh-man Defender Technical Discussions 59 December 4th, 2014 08:59 PM
300 Tdi Low-End Boost/IP Tuning Jackie Treehorn Defender Technical Discussions 55 August 13th, 2014 07:06 PM
Hella Euro 7 Pin to 4 Pin Trailer Wiring Adapter Wolf Fabrication For Sale - Parts 2 February 28th, 2013 02:57 PM
Boost Lost on 200 TDI Rugbier Defender Technical Discussions 17 August 26th, 2010 05:40 PM
D90 caliper brake pin - cotter pin help Gardrover Defender Technical Discussions 4 May 29th, 2009 02:01 AM
