Tankless Water Heaters (On Demand) for the home - Page 2 - Defender Source
Old June 3rd, 2013, 06:45 PM
RoverC
Cliff
1997 D90 ST
what if you dont have gas, only electric, do they make them for that application?
Old June 3rd, 2013, 06:49 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Yes.
Robert Deniro
Old June 3rd, 2013, 09:56 PM
themaxx's Avatar
themaxx
Ade
94 ST
Yes, but from what I've read, they don't compare to the gas units. Most electric units require an upgrade of your electric panel, because the tankless will require 2 sometimes 3 dual pole 40 to 60 AMP breakers...depending on the size of the unit needed. Expect the lights to dim when you turn your faucet on.
If you plan to go electric still, the reviews I've read about the ECOSMART ECO tankless units have been great. Made in the USA! Sold by Home Depot online.
An alternative, not sure if it's economical would be to go with a propane tankless. If you go with a 420lb propane tank, it falls in the sweet spot for size and not having too be a distance from the house...I'm sure regulations are different in other States/County.
------ Follow up post added June 3rd, 2013 10:01 PM ------
Originally Posted by airbornrover View Post
Cant you just have a gas manifold put in?
I'll have to ask, I'm sure the answer will be know, but I'd like to know why.
Old June 3rd, 2013, 10:07 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
You are correct about dimming the lights. I just had a service call on an electric tankless. Three 40 amp circuits. The electric ones make me a little nervous as every time I have had to check one out the techs are really concerned about the elements and them having a fault. They all choose their words very carefully when they get to this part of troubleshooting. It always make me wonder.
water
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Water leak Jon D' Defender Technical Discussions 1 September 5th, 2004 08:34 PM
