Tailgate conversion from Fold down to Swing open - Defender Source
Old November 2nd, 2015, 09:51 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Is there hardware readily available to change a fold down tailgate on a Tithonus or Series from the fold down style into a swing to the side to open style tailgate? I rarely see people using the later style but I'm curious of what bits would be needed to do that job.
Thanks for the feedback.
Old November 2nd, 2015, 09:57 PM
johan's Avatar
johan
johan
2009 Range Rover
I have one like that. Just two standard hinges and a door opener. Will make some pictures later this week, doesn't look a difficult conversion.
Johan
Old November 2nd, 2015, 10:08 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Nice. I didn't think it would be too challenging so that's good to hear.
Do like it set up that way and are there any advantages you like about that set up? Basically what made you decide to do that.
Old November 2nd, 2015, 10:19 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Somewhere I have a to-scale template for where to drill the key hole if you use a standard locking latch, if you would like it. I used the fold down brackets to keep the tailgate in place then drilled holes for the side hinges. I opted to place the side hinges in the same position they would need to be for a full rear door, in case I ever swapped to a full door.
Old November 5th, 2015, 09:40 AM
WBSurfer's Avatar
WBSurfer
1995 RRC
Yep. I'll take it. Thanks
------ Follow up post added November 5th, 2015 09:40 AM ------
Yea...post up a few pics when you get chance. Thanks
Old November 5th, 2015, 01:22 PM
Rugbier's Avatar
Rugbier
Gustavo
Plenty of kits available in the UK , the one I have bought did not required any new drilling if you keep the upper left locking mechanism, if you want it all NAS 90, you have to drill.
The difficult decision you will have to make ( many have opted to keep the original fold down lock ) is replacing the locking mechanism.
I have to look where the hell I have mine, when ready to install, I changed my mind and decided to keep the original fold down
NO SIGNATURE
Old November 5th, 2015, 07:58 PM
johan's Avatar
johan
johan
2009 Range Rover
herewith some pictures.
THe hinges are on the same place as a standard door.
THe door handle is a little lower and holes have to be drilled for the door catcher
ID:	134028   Click image for larger version
ID:	134030   Click image for larger version
Johan
conversion, tailgate, wing
Fold down tailgate bracket ? dave_lucas Defender Technical Discussions 15 March 24th, 2012 01:55 PM
OPen loop stall, or at least I think it is open loop! Neo Defender Technical Discussions 18 January 25th, 2012 11:34 AM
Tailgate Conversion: drop-down to swing-away MUDSUX Defender Technical Discussions 10 August 31st, 2010 09:40 PM
How to convert a ROW fold down tailgate to side swing? evilfij Defender Technical Discussions 5 May 20th, 2009 11:23 AM
ST Tailgate conversion to drop down wcampbel@nas.edu Defender Technical Discussions 11 February 10th, 2009 05:25 PM
