Tail Light Boot Installation - Fixing Hosed Tail Lights - Defender Source
Old October 24th, 2004, 09:52 PM
My tail lights and brake lights were intermittent and on the blink, so having recently removed the rear harness from my disassembled d90, I took the opportunity to install the tail light boot kit available from Rovers North.
The pix pretty much lay it out, but here are some explantory captions:
1) No surprise that the lights were hosed, all that corrosion in the connectors...
2) This is basically the contents of the kit, x5 of each piece. At like 150ish bucks, its not what I would call a "great value" even with the tube of Wurth's silicone sealer thrown in to sweeten the deal.
3) There isnt a lot of wire to work with (especially if some hack has worked on your tail lights under warranty) so I had to get agressive with binder clips to hold the boot back while I soldered.
4) I hate soldering, so after much swearing, I had 5 completely installed boots. If I was doing this on the truck I would have just crimped the connectors. I used layers of heat shrink tubing to fill the space in the tail of the boot instead of the silly cone sealer. I figure it will do a better job of sealing the end and will not be a mess to remove later if I want.
I'm happy with the result, and the look like they'll work nicely. Time will tell how they hold up in service.
Name:	Tail Lights 1.jpg
ID:	1699   Click image for larger version
Name:	Tail Lights 2.jpg
Name:	Tail Lights 3.jpg
ID:	1701   Click image for larger version
Name:	Tail Lights 4.jpg
Old July 11th, 2017, 04:14 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
Hey thanks for this post! I know it's old, but over 13 years no one seems to have appreciated it.
The boots are still available from Land Rover North America. I ordered some. They're part number LRN000004.
ht, installation, lights, tail lights
Need tail light lenses and Jerry can holders Cyborg Wanted 2 January 13th, 2006 12:20 PM
Rear lamp guards (tail light) mod4b Wanted 1 August 2nd, 2005 05:06 PM
Tail light in the dark... OCD90 Defender Technical Discussions 16 June 1st, 2004 12:31 PM
94 Square Tail lights switch to 95/97 ?? mfreeman17 Defender Technical Discussions 12 May 17th, 2004 04:58 PM
tail light guards ronward Wanted 3 April 5th, 2004 11:14 AM
