Switching to bio diesel - Page 4 - Defender Source
Old April 13th, 2014, 06:07 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Yep, it sounds like you did a retrofit conversion to 300Tdi. I'm doing a conversion from an existing 2.5NA diesel. Not sure if the fittings are the same size but I'm guessing that I'll need 5/16 ID. Maybe someone with the same setup as me can chime in.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old April 13th, 2014, 10:35 PM
Consider putting the ends of the 1/4" hose into hot water for a minute to soften it up before pushing it on.
Originally Posted by pendy
I'm here for the D's
Old April 13th, 2014, 11:39 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
The stuff I had at first was that gorilla hose and it has an enormous sidewall. I tried the hot water trick but it didn't help. I'll give it another go with 1/4" viton next weekend and see how it goes.
Old April 14th, 2014, 07:41 PM
cbfritz_03
Carmen
none
Running with biodiesel is another reason I want to swap the gas engine to diesel. Alternative fuels.
Old April 14th, 2014, 11:37 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I think the pickup is 10mm OD / 8mm ID and the return is 8mm OD / 6mm ID.
Old April 15th, 2014, 12:35 AM
eco 45's Avatar
eco 45
Scott Oncken
running or non?
Parker has a biodeisel rated hose that works well that is 5/16 that I have used on several older rovers. Just finishing up a late series IIA and ran 5/16 from the stock tank to a 2.8 under the hood. The fittings on the lift pump are slightly larger, but the 5/16 slips on without too much effort. Been running biodeisel for many years and this hose has held up well. I used the 5/16 for the return line as well.
Scott Oncken
Sisters, OR
541-550-6300
eco 45 on all forums
Old April 15th, 2014, 12:36 AM
chris snell
Chris Snell
87 Ex-MOD 110
Finally, an answer. Thanks Matt.
2013 LR4
Old April 15th, 2014, 01:06 AM
mattarm's Avatar
mattarm
Matt
1993 D110
some additional info and Mcmaster has some tubing listed at http://www.mcmaster.com/#standard-pl...tubing/=rjiwn8 where you can filter for biodiesel and other attributes on the left side of the page.
Old April 15th, 2014, 07:46 AM
Broncoduecer
peter
D90
Also good prices on viton here: http://www.coleparmer.com/Category/Viton_Tubing/6782
Old April 15th, 2014, 12:55 PM
I used McMaster Viton (green) hose as dimension spec'd by Mark above. They work great.
Old April 15th, 2014, 01:07 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Has anyone found a good source for Viton fuel filler hose?
Old April 15th, 2014, 01:57 PM
chris snell
Chris Snell
87 Ex-MOD 110
So it looks like the correct Viton hose for tank --> sedimenter --> front of truck is McMaster part# 5119K86
2013 LR4
Old April 15th, 2014, 02:19 PM
Without reading back... The stock nylon tubing is fine with BD and cheap as hell.
Old April 15th, 2014, 02:38 PM
And tough as a crackhouse pit bull. I used clear nylon for most of my runs. You hit it with a heat gun and slide it on the barb and robert is your mom's brother.
Old April 15th, 2014, 08:16 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It is if you make sure there's not a kink in it that will pool fuel. Mine started softening and sweating from B99 puddling. Once adjusted it's been fine.
Old January 22nd, 2015, 11:43 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
In researching fuel hoses for my Webasto I found this in the interweb. Have not verified it myself. I'm considering going with the Gates Barricade Fuel Line. Any thoughts or comments on that one?
Biodiesel Compatible Fuel Lines
Goodyear part numbers 65148 thru 65153 & 65161 thru 65163 meet SAE specification J30R9. B100 compatible.
Gates part number 4241G and 4241M for marine use.
Kuriyama part number A4143.
NAPA fuel injection hose part H205.
McMaster Carr Viton rubber tubing part number 5119K51.
Apparently any USCG approved fuel line with SAE J1527 type A-1 approval is B100 compatible.
Old January 22nd, 2015, 11:52 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The H205 has been superseded to H357A.
Very useful info... thanks for posting.
RDavisinVA
Old January 22nd, 2015, 06:26 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Does anyone know the PSI requirements of the fuel lines for a 300tdi? I am trying to determine the working pressure for the lift and injection pump as well as the Webasto Thermotop C pump. The fuel line I was going to buy has an operating pressure of 50 PSI. Is this sufficient? I've read somewhere that the fuel lift pump pressure is 3-4 PSI @ 1800rpm. What about the injection pump? I just want to make sure I get a biodiesel compatible fuel line with the adequate PSI rating.
Old March 13th, 2015, 01:58 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
1995 NAS Defender 90
Fuel Line
I talked to Webasto and decided to order their own branded fuel line. The tolerance is a little different they said so important for best fit. The line and the Thermotop C are rated up to B20 (20% biodiesel). Their line is ordered by the meter and the part# is 9028379A.
Tiktaalik™
Old March 13th, 2015, 02:01 PM
your pretty much under 10psi for everything except for the metal IP to Injector pipes. Don't sweat it. (pardon the pun)
Mark Kellgren
KM4BOR
diesel, switch
Any interest in Bio Diesel Stickers for your Land Rover? Manimal The Flea Market 57 May 14th, 2009 03:04 PM
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
bio diesel jimmy salmon Misc. Chit-Chat 2 June 28th, 2007 08:45 AM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
