Swing away jump seats - Defender Source
Old September 16th, 2012, 02:05 PM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
I've seen it posted somewhere but can't seem to find it. Where does one find those full size swing away rear jump seats?
And a follow up question:
Does anyone have opinions about the bestop rear bench seat? Would it look odd in a SW? http://www.quadratec.com/products/24277_10XX_PG.htm
Old September 16th, 2012, 02:31 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
http://www.safarihp-trim.com/index.p...mart&Itemid=13
The only problem with the bench seat in an SW is resolving the seatbelt problem. They're built in as part of the lock&folds.
-Ren Ching
Old September 16th, 2012, 02:49 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Has anyone done the full upgrade to Exmoor seating, swing ups in the tub and upgrades in the front with primo seats...pretty expensive when its all said and done you're talkin 4k. Not cheap but is it worth it trying to marry comfort, safety and not worring about ruining the material with a little mud and water! (not that I would EVER get my 90 dirty)
Old September 16th, 2012, 05:14 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
The exmoor stuff looks great but man is it expensive. $4k for seating seems insane!
I have been researching the Corbeau Bajas - fixed backs for the front and a fixed back bench for the rear. The bench I would plan to mount it facing backwards so the kids would use the back door to get in and out. I want to make everything easy to remove so when I need space it is there. Still need a bunch of planning and might just need to order some stuff to see how it fits.
Old September 16th, 2012, 05:57 PM
Bill Larson
Bill Larson
I like Corbeau, but it doesn't maintain the "look" thats why I'm thinkin Exmoor.
Old September 16th, 2012, 08:39 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Ive got the Exmoor lock n folds. Trimmed in G4. I love em but won't work if the cargo is over 5'4" with top on.
Old September 16th, 2012, 08:56 PM
ndrenfro's Avatar
ndrenfro
Nathan Renfro
1997 Defender 90 SW
Im in the process of getting the new style lock n folds installed in rear and dropping puma fronts in (all in XS trim). I should be able to post some pics later this week.
Old September 17th, 2012, 12:29 AM
Surf90's Avatar
Surf90
C.S.
Man those lock n folds just seem so slick!
Old September 17th, 2012, 01:08 AM
CDeWan
Clay DeWan
5.3L beastie
Regarding the lock and folds - do you guys think it would look retarded to install 2 passengers side seats, one facing backward and the other forward for ease of entry?
Since the tailgate swings open from left to right I was thinking it would be easier than having them side by side with no room for someone to squeeze between them if they both were in the open position.
Old September 17th, 2012, 01:20 AM
Bill Larson
Bill Larson
Some passengers might have more of a problem with that. Car sickness/motion sickness can be triggered by weird things. It would look different, but who cares right. You could try it. I thought about staggering them, but I'll opt to just do side by side.
Old September 19th, 2012, 08:40 AM
ndrenfro's Avatar
ndrenfro
Nathan Renfro
1997 Defender 90 SW
Here's some shots of the new style exmoor lock and folds.
ID:	57773   Click image for larger version
Old September 19th, 2012, 08:46 AM
Bill Larson
Bill Larson
Nathan that looks really good! are you happy with the way they turned out? Did you do the install? How did the fronts turn out?
Old September 19th, 2012, 03:38 PM
CDeWan
Clay DeWan
5.3L beastie
Damn those look good. The are so on my radar screen!
Old September 19th, 2012, 06:55 PM
ndrenfro's Avatar
ndrenfro
Nathan Renfro
1997 Defender 90 SW
Bill-I'm very happy with how they turned out, and so are my kids. Now they can finally ride in daddy's new car. I did not do the install, Blue Ridge Rover Works did. They did a great job. They are solid seats, mounted well. I decided to take out the rear window trim pieces to fit the belt holder, instead of drastically cutting the trim. The puma fronts are matching XS trim. I'll post a pic later tonight.
Old September 19th, 2012, 07:41 PM
Bill Larson
Bill Larson
it looks fantastic and I think you pushed me over the purchase edge to get these. I'm going to do the install myself as I am taking everything out anyway to do other upgrades. Did you have the front seats swapped out also?
Old September 20th, 2012, 08:44 AM
ndrenfro's Avatar
ndrenfro
Nathan Renfro
1997 Defender 90 SW
Here's the matching puma fronts.
ID:	57845   Click image for larger version
Old September 20th, 2012, 09:40 AM
smob's Avatar
smob
Steve
Hey Nathan, would you mind taking pics of the belt mounting brackets? Just wan to see how the seat belt attaches to the corners of the truck. Thanks.
-Ren Ching
Old September 20th, 2012, 09:49 AM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
Those pumas look really good and the exmoors are just bad ass on their own!
Old September 20th, 2012, 11:44 AM
ndrenfro's Avatar
ndrenfro
Nathan Renfro
1997 Defender 90 SW
Here's a couple shots. You can see the black brackets you have to buy separately to attach the belts.
ID:	57848   Click image for larger version
Old September 20th, 2012, 12:06 PM
smob's Avatar
smob
Steve
Ah, yes, I see how they fit. Many thanks.
-Ren Ching
jump seat, seats, wing
4 Rear Jump seats, mint dmarchand For Sale - Parts 11 October 15th, 2005 03:00 PM
Looking to buy Jump seats for a D-90 ST johnnyg15 Wanted 0 April 4th, 2005 09:45 PM
jump seats wanted naeirie Wanted 0 September 25th, 2004 03:30 AM
Jump seats for rear / Hard Top doozle Wanted 5 June 5th, 2004 07:47 PM
FS: Four SW Jump Seats from 95 D90 DJ Menasco For Sale - Parts 4 December 19th, 2003 12:28 AM
