Swapola - Defender Source
Old December 19th, 2004, 04:22 PM
Swapola
Some pics from today! Looks like one of thesprings on the clutch is broke, and I need a new throw out bearing. Man is that bell housing dirty!
ID:	2142   Click image for larger version
Old December 19th, 2004, 04:54 PM
Oh god, it was a huge hassle to get my old motor out with the fenders off and everything removed - I'm glad I'm not you! Of course I pulled mine with r380 and LT230 attached, but still... and you didnt even remove the brush guard. I hope you have a clutch alignment tool for reassembly.
Although I dont know why you went to all the trouble to remove and replace the motor - you should have just used the "Fixing Kit!"
Old December 19th, 2004, 05:42 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Did somebody throw up in front of your truck? LOL.
No really, I am glad I am not you, though I know an engine swap is not long in my future.
"It's not a Jeep"
Old December 19th, 2004, 05:54 PM
Well according to the manual I need to replace the whole clutch, because one of those little springs is broke. Nope, no I don't have a clutch alignment tool, there must be a way to do without? I tried the fix it kit, and no luck. Jesse, I drove into 3 feet of trowup and thats when all my problems started. So any guesses ae to what else will go wrong?
Old December 19th, 2004, 06:01 PM
what you gonna replace with mike? I feel like I read somewhere around here you were gonna put in a 4.0?? I put a 350 na jeep once we didnt use the alignement tool. when we found it we were like maybe you use that to line things up..
Old December 19th, 2004, 06:12 PM
Dave Merchand's old 4.0 is going in. I don't remember anything about an alignement tool in the manual, but I could have missed it. I bet it is doable without.
Old December 19th, 2004, 07:42 PM
Alignment tool - its just a big help, you can get one from RN for less than 20 bux. It just alows you to line everything up during clutch assembly and transmission installation. I did mine without, but you just have to gently make an attempt, turn the input shaft a hair, and try again until it slides in.
Old December 19th, 2004, 08:18 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Or you can use an old input shaft from an old trans if you have one lying around.
Legend in My Own Mind.
Old December 19th, 2004, 09:08 PM
JBurt's Avatar
JBurt
Jesse McCoy
So am I gonna need a clutch alignment tool when I swap my clutch out?
Mike, Sorry about the throw up. I think that's what made my clutch go squirrelly too.
"It's not a Jeep"
Old December 19th, 2004, 09:17 PM
The tool just makes it easier, worth the 15 bux in my view.
Old December 19th, 2004, 09:24 PM
Hmm for 15 or 20 I think I'll get one, when you first said I needed a special tool I though it was going to be $$$$$$. And after I use it I'll send it over your way Jesse. The clutch is easy to get off, it is just all that other stuff you need to do to get to it.
Old December 19th, 2004, 11:10 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
The main idea of the alignment tool is to simulate the input shaft from the tranny to help center the clutch disk. It's possible to do the job without it, but the alignment tool sure does make it easier. That disk MUST be centered under the pressure plate, or you just ain't gonna get the tranny on.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 20th, 2004, 07:16 AM
RN Part Number TLS33D - 14.50
Old December 20th, 2004, 07:48 AM
Thanks Jim! Oh and to answer one of your first questions yes, brushgaurd left on! The engine lift my father could lift the engine high enough to clear the brushgaurd with room to spear!
Old December 20th, 2004, 08:59 AM
JBurt's Avatar
JBurt
Jesse McCoy
Maybe I'll get one from Santa, I'll write him a letter right now so he knows I want it
"It's not a Jeep"
Old December 20th, 2004, 09:07 AM
Jesse, when you write santa can you tell him I have been really good! I need allot of stuff.
Old December 20th, 2004, 09:08 AM
That you want a TLS33D or a 4.0 motor?
Old December 20th, 2004, 09:12 AM
No, a new clutch, a Megasquirt (replaces ECU), a heated Garage, and a good looking mechanic! I could go on but I think that would be pushing it.
Old December 20th, 2004, 09:55 AM
JBurt's Avatar
JBurt
Jesse McCoy
Mike, that's exactly what I asked for!
"It's not a Jeep"
Old December 20th, 2004, 09:58 AM
LOL! I think the only one I'll be getting is the clutch, and It's not even from Santa! What did I do to get on the naughty list?
