suspension fault lr3 - Defender Source
Old July 20th, 2015, 11:01 PM
phunter
phunter
1993 NAS 110
got new cooper zeons put on and 3 days later get the suspension fault display and amber light. it says must remain in normal mode.
the compressor cover does not look cracked or damaged in any way from the shop installing the tires. the truck is 2007 with 85k miles and I am original owner. the compressor will raise and lower the truck initially. The message and light coming on once you begin driving. The compressor may have been running more lately but my wife cannot be sure.
Anyone willing to give an opinion how to proceed?
Do I go to dealer to get codes read?( I do not want a large repair bill if I can help it).
Do I attempt to replace the compressor empirically given age and mileage of truck? Is this a difficult job?
Does the dealer need to reset things if the compressor is replaced empirically?
Thanks for any input.
Old July 20th, 2015, 11:29 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Sounds like the compressor is going, given the miles and the fact that you are probably dealing with more humidity now than normal that's not terribly surprising. You could rebuild the hitachi or just replace with the AMK unit. (or if you want to go nuclear, replace with coils).
If you do the rebuild I don't think you need to reset, AMK requires re-flash.
Old July 21st, 2015, 04:59 PM
Erik@Lucky8's Avatar
Erik@Lucky8
Erik
1985 D110 Ex-MOD & a few others
I think that the correlation between the tires and fault light are purely coincidental. I do not believe that your new tires are causing a suspension fault. I agree with Ray. If you are on the original hitachi, then you were on borrowed time as it was. I replaced the hitachi in my 2006 at 75k miles and again at 150k. I highly recommend you do the AMK if you plan on keeping it. It is easy enough as Ive done them in under 30 minutes. I have the full Genuine kits for $740/delivered if you need one. I include instructions as well. Reflash is generally required, but I have seen a few be installed without needing it. There is no rhyme or reason to these things.
Current:
2007 Range Rover L322 - 4.4L HSE LUX
2003 D2 - Monte Carlo Blue 2" TF lift
1991 RRC Hunter - 2" OME
1985 D110 EX-MOD
Gone:
2006 LR3
2004 D2
2001 D2
2001 D2 - Lucky8 Project D2 - REDUX
2000 D2 - Trail Project, maybe
1999 P38
1995 RRC LWB
Old August 3rd, 2015, 11:31 PM
phunter
phunter
1993 NAS 110
I did the rebuild to include desiccant,springs, o rings. This did not fix the problem. After a 15 minute drive, the amber light and fault code stating normal height only returned.
Does anyone know if the code has to be cleared at the dealer in order for the rebuild to work??
How to proceed? Unplugging battery help in any way?
Thanks for any advice
Old August 4th, 2015, 12:51 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Paul-
You can see if a hard reset fixes the codes, a lot of times there are 'ghosts' in the system of residual codes. (google it, but the basic version is to detach positive/negative cables, join them with a long screwdriver or something, and let it sit for ~10min)
This is why I think an IID tool is pretty much mandatory if you want to do anything substantive with the truck. It's a great investment and Lucky 8 can take care of you there.
r-
Ray
Old August 4th, 2015, 05:53 AM
Ray_G's Avatar
Ray_G
Ray Gerber
BTW, this may shed some potential light too:
DISCO3.CO.UK - View topic - EAS problems remain after rebuilding compressor
Old August 4th, 2015, 08:06 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Interesting, the same exact problem started happening with my 2008 LR3 2 weeks ago. Starts off fine but within 2 minutes the amber light comes on and says normal height only. Before the light comes on I can raise and lower the truck and it drives fine after the light comes on. I used my Faultmate to pull the codes and it says:
U0421-Invalid Data Received From Suspension Control Module
I clear it but it comes right back.
MUDSUX
Old August 4th, 2015, 09:55 AM
Erik@Lucky8
Erik
Unfortunately if your compressor was beyond the point of no return, the rebuild is fruitless.
Current:
1985 D110 EX-MOD
Gone:
2006 LR3
2004 D2
2001 D2
1999 P38
1995 RRC LWB
Old August 4th, 2015, 11:29 AM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
The compressor on our 2005 went at around 85,000 too. Just did a complete replacement. Eric is right. Sounds like yours was at the same point.
Old September 23rd, 2015, 09:36 PM
phunter
phunter
1993 NAS 110
suspension compressor lr3
after rebuilding the compressor with no luck, I am thinking a new compressor is the next step.
amazon has an off brand compressor by the name of APDTY 050011 that is around 250 dollars cheaper than hitachi. Anyone with experience with this compressor? Do you get what you pay for or is this a good direction to go in?
Old September 23rd, 2015, 11:44 PM
jafir's Avatar
jafir
Jafir Elkurd
Based on the photos, it LOOKS like a hitachi compressor. I'd be tempted to use that, it's the best price I've seen for a compressor.
Old September 24th, 2015, 12:01 AM
Tarheeld
Bill
1985 110
Paul, I had the same symptoms on my 06 LR3 HSE. I, too, changed the desiccant and it did not make squat of a difference. However, when I changed the piston arm seal, that did the trick. If you were able to change the desiccant; changing the piston arm is easy and worth it before chucking out the compressor. Mind you, all these shenanigans occurred smack dab at 60000 miles.Also, check to make sure there are no leaks around the quick connect tubes.
Land Rover LR3 Discovery 3 Air Compressor Replacement Piston Seals Repair Kit | eBay
Also, after I fixed the suspension issue, I sold it!
Old September 24th, 2015, 06:59 AM
You need to go to a dealership or Rover specialist to have to fault codes read. There are so many things that could be causing the fault, its silly to just throw parts at it.
Old September 24th, 2015, 07:18 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Odd question but are the Coopers standard or oversized?
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old September 24th, 2015, 09:00 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
what Jimmie said....
I don't know the exact number, but I have fitted dozens of AMK compressors to fix mysterious happenings with RLC on the LR3's. that being said, I'm at 140k on my original Hitachi.....
Another option if one wanted to replace the compressor- Dunlop offers a drop in replacement for the Hitachi that wont require a re-flash.
Email is
Same place, new dogs.
Old September 24th, 2015, 09:16 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I just returned this compressor to Amazon. I'm having the same issue and decided to try the cheap route too... I figured with Amazon Prime I could return it if it doesn't fix the issue. It's a direct replacement, but it's loud as anything (noise generally doesn't bother me, but this is noticeable) and after a minute of running it sputters a bit and then I get a suspension fault.. so it didn't fix the issue.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old September 24th, 2015, 01:02 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Is this the go to piston seal kit that everyone uses? Also, what is the best place for the desiccant?
Old September 24th, 2015, 01:08 PM
Tarheeld
Bill
1985 110
I believe you can use any desiccant in theory. Personally, I got my kit from Kieran. Bloke sent me an extra piston ring for free when I buggered it. It has all the replaceable components. If this doesn't work, your best off replacing the entire contraption. They sell cheaper kits, with the desiccant only as well.
https://x8r.co.uk/index.php/land-rov...i-end-cap.html
Old September 24th, 2015, 01:18 PM
down_shift's Avatar
down_shift
Russell
Thanks, that helps. Just located the same kit on eBay from what appears to be a LR dealer. $71 shipped.
06' with 68k on the odo and the air system appears to be working fine (knocking on wood right now....). Should I go ahead and do the rebuild now (rings and desiccant) or wait until an issue presents itself?
http://www.ebay.com/itm/LAND-ROVER-R...3D161589143385
Old September 24th, 2015, 01:36 PM
Tarheeld
Bill
1985 110
Quite frankly, its a b***H to take out the compressor; there's a hidden bolt. Additionally, the plastic tubes that feed into the compressor are usually melted on to the fittings due to age and also are another weak point while removing the part. I cut the tubes in a straight section and went for quick connect fittings. If you ever need the exact sizes, let me know, I have them somewhere.
Given the above, I'd just wait for the problem to present to attempt a repair. FWIW, I never used the suspension control and yanked the fuse in Engine Bay to deactivate the system in Normal height mode.
Land Rover Range Rover Sport Air Suspension Compressor Repair Kit X8R | eBay
lr3
LR3 Suspension Fault speedpin Misc. Chit-Chat 8 February 1st, 2015 07:14 AM
LR3: 7 degrees F = Transmission fault? down_shift Misc. Chit-Chat 5 January 8th, 2015 12:44 PM
Lr3 suspension Rugbier Misc. Chit-Chat 30 October 22nd, 2014 11:57 PM
Lr3 suspension fault lordhelemt Defender Technical Discussions 7 June 29th, 2014 09:14 AM
LR3/LR4/RRS Air Suspension Compressor Blowout discojosh2000 For Sale - Parts 0 December 30th, 2011 09:51 AM
