surprised at 300Tdi cold weather starts - Defender Source
Old December 3rd, 2006, 06:17 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Went out to start the Rover this morning at a brisk 9 degrees fahrenheit and was amazed that it started right up...amazing. My old 6.2L Chevy Blazer diesel wouldn't even crank at 32 degrees without a block heater...I wonder just how cold it has to be to prevent the 300tdi from starting up?
Old December 3rd, 2006, 07:37 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Not sure how cold it has to be to have issues. I ended up removing my glow plug switch all together. Here in Cali I haven't needed the glow plugs once. Even up in Big Bear when it was in the mid 30's.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 3rd, 2006, 08:13 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I've had no issues starting up at 10 and 20 below 0F in Maine when the glow plug is used.
Although getting any cabin heat at those temps is an issue...
Old December 3rd, 2006, 09:45 PM
Gkase's Avatar
Gkase
George Kase
David,
if that is true...I guess I don't need to bother with the espar coolant heater...cabin heat doesn't matter to me, but not starting does...
Old December 3rd, 2006, 09:55 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I would still go with the heater, or at least a block heater of some kind if you are starting in those temps daily. It will only help the engine.
Old December 4th, 2006, 11:11 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I only hook up my glow plugs when it gets below 30deg. when its warm out, I have them unhooked.
Legend in My Own Mind.
Old December 6th, 2006, 09:11 AM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
Well, that depends to some extent also on what oil you have in the sump and how big your battery is. I have 5w30 synthetic and something like 900 CCA on my battery, and at -30 C my 300Tdi was no go. I have since installed a coolant heater that runs off of mains electricity for winter weather. I have noticed quite rough starting even at around few degrees below zero C, if no pre-heating is used.
I agree that some kind of block/coolant heater would be good for the engine if you are going to be running it in temps lower than -5 C regularly.
Cheers,
300tdi, start, tdi
Cold Starts JBfoot Defender Technical Discussions 0 November 3rd, 2007 06:45 AM
Cold Weather Starter Problems boshea Defender Technical Discussions 9 October 25th, 2005 04:35 PM
Excessive Cold Weather Exhaust boshea Defender Technical Discussions 3 January 9th, 2005 02:44 PM
1st really cold weather questions mspell Defender Technical Discussions 6 December 20th, 2004 08:40 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
