super unleaded or regular - Defender Source
Old November 20th, 2005, 09:57 PM
Rover- Girl
Guest
Posts: n/a
Well, I know it's a V8 but its not a high performance engine...right !!??
I been putting mid grate in my D90...is this good enough ?
Just wondering.....
Old November 20th, 2005, 11:07 PM
stevewhitaker's Avatar
stevewhitaker
Stephen Whitaker
1994 D-90
Hi Christine. Mid-grade should to just fine assuming the engine is tuned properly. The compression on the engine is just below that where premium is required. I can run regular in mine for normal driving with no ill effects - - unless I really load up the engine by punching the gas while in top gear at low RPMs, then I hear some slight pinging. If you hear some detonation (pinging) while under load, step it up a notch to higher octane, otherwise save your $$.
Old November 21st, 2005, 07:35 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I disagree. The manual says 93. I thought I could get away with mid grade and tried it. The truck did not like it. I went to super and all was well.
I know of one other truck with the exact same results.
EwS
Old November 21st, 2005, 07:57 AM
scoloco's Avatar
scoloco
'94 D90 ST
EwS
How did your engine tell you that it didnt like low octane?
I'd sorta agree with Steve - you can try the lower octane and see if it works. If it does, good for you. If not, go back to the good stuff. Pinging is a good clue to up the octane.
Generally at higher altitudes you can get away with using lower octane fuel. Howevever, on my couple trips across country last year, I noticed that the regular was the same price, but 85 instead of 87 octane, premium was 89 instead of 91, but they were charging lowland prices.
Old November 21st, 2005, 08:46 AM
super
Old November 21st, 2005, 09:09 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
It ran like shit.
Old November 21st, 2005, 12:27 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
When my engine was all original, it pinged a lot under load on 87/89 gas.... pinged a little bit with 91.... ran fine with 93.
After putting in the composite head gaskets, it runs fine on mid-grade with no pinging in any conditions.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 21st, 2005, 01:40 PM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
I used to use regular and my truck knocked a little bit and ran like shit. I switched to premium and it ran great.
"tell them to phucough"
Land Rover-The Best 4x4xFar
Old November 21st, 2005, 11:27 PM
AggieD90's Avatar
AggieD90
Kevin Collins
'95 AA Yellow & '97 Willow Green
I made a deal with mine once...
I told it when it decided to use less fuel it could have higher octane again. I started using regular and experienced no problems. If they developed someone would have to speak with the current owner. I asked my dad (a petrol engineer) and he said the same thing to me others have said. Try it...if it runs okay...it'll be fine. I run regular in my '95 Classic - 130K miles and ask anyone who knows me - it's the holy grail of LRs.
Old November 22nd, 2005, 08:11 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
My 90 seems to be allergic to anything but the top grade of gasoline.
I got your JEEP thing, now it hurts when I pee!!
Old November 22nd, 2005, 09:05 PM
Rover- Girl
Guest
Posts: n/a
Thanks...
Truck runs great on midgrate...
I'll guess I stick with it
Old November 28th, 2005, 06:31 PM
rustydefender
Russell Newton
97 D-90 sw
Why do european cars always tuned for premium? It is a buick derived v-8 isn't it?
Old November 28th, 2005, 06:39 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
difference is pennies between grades in the UK
3rd low and BOOT IT
Old November 28th, 2005, 08:30 PM
rustydefender
Russell Newton
97 D-90 sw
Almost everybody does diesel over there right? Why not engineer a v-8 that runs on regular for the u.s. market or better yet get a an epa certified diesel!
Old November 28th, 2005, 11:18 PM
Hans's Avatar
Hans
Hans Haase
It wasn't until recently that the Europeans had the same fuel restrictions as us. So they could support the higher compression ratios without the same problems as here in the US. Heck, I think they only recently got rid of leaded fuel.
-Hans
My oil line fix
Old November 29th, 2005, 08:57 AM
WCURoverD90
Jason Habbal
Because that would make too much sense.......
Old November 29th, 2005, 10:59 AM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I've been experimenting with colder plugs. Went to NGK B8ES plugs and that cut the pinging quite a bit. Now I have B9ES for a couple of days (changed this weekend) and zero pinging (so far!). I need a nice hot 85 degree day to know for sure.
Each colder plug lowers the combustion chamber temp by about 80 degrees. Drawback is that colder plugs fowl easier. Only time will tell....
Doug W.
Set of 5 Q78 Super Swampers RedRhinoProducts For Sale - Parts 1 February 1st, 2006 06:43 PM
1995 Triumph Daytona Super III lrnasd90 For Sale - Vehicles 4 April 18th, 2005 08:26 PM
Super Siphon Davis Misc. Chit-Chat 5 November 8th, 2004 11:47 PM
35/16/15 Super Swamper TSL Boggers & rims TDI Guy For Sale - Parts 4 October 18th, 2004 10:18 AM
35x12.50r16.5 Super Swamper SSR's and aluminum wheels Chris Cox For Sale - Parts 0 July 12th, 2004 04:24 PM
