Stuck Throttle - Defender Source
Old June 16th, 2012, 08:59 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
Stuck Throttle
Had a fun moment on the motorway today. Went to pass someone in the 90 and stuck my foot down hard on the accelerator to downshift and the pedal stuck down. Shifted to neutral and pulled into the hard shoulder to figure out what was up.
Turned out my thick rubber mats had shifted around and the thread on the bottom of the accelerator pedal pierced right through them and stuck in place.
Check your mat clearances I guess
Old June 16th, 2012, 09:27 PM
Glad you figured out the problem pretty quickly.
Old June 20th, 2012, 02:47 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Here is something everyone should do....
The sharp point on the pedal stop gets stuck in the floor Matt rubber.
Nothing like accelerating away from a light and when you step on the clutch the engine bounces off the rev limiter :-)
Had to put my toe under the pedal and pull it up...considered letting the truck recklessly accelerate and make a panicked call to 911...but figured out stepping on the clutch would be a less dramatic option...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old June 20th, 2012, 04:46 PM
I've had it happen once.
Old June 20th, 2012, 05:07 PM
Build up of gunk in the throttle body is also known to cause this.
Old June 20th, 2012, 05:22 PM
Naplm00
Matthew
and stuck cables on diesels
Old June 20th, 2012, 10:57 PM
NomaD110
Christian
1993 Defender 110
See now this is what I call reasonable action to a problem. How many times have I heard on the news some moron call 911 because the accelerator stuck wide open?
Old June 21st, 2012, 07:59 AM
I want to know which car was slower that he was attempting to pass.
Old June 22nd, 2012, 12:24 AM
brettm's Avatar
brettm
Brett
It was some new Porche 991. Ca plates. Full of hoochies. Plate was McCauley1 if I remember correctly.
Old June 22nd, 2012, 07:51 AM
So you two had an automatics-only drag race?
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
Pinging under full throttle... Doug Defender Technical Discussions 10 November 29th, 2005 11:02 AM
Throttle body size on a Thor manifold? Hans Defender Technical Discussions 1 March 10th, 2005 10:10 PM
Stuck In Iraq javelinadave Misc. Chit-Chat 5 April 12th, 2004 07:53 PM
Hand Throttle sherpamike Defender Technical Discussions 19 April 3rd, 2004 12:23 AM
