Strange possible central locking problem, '04 D2 - Defender Source
Old November 18th, 2014, 10:21 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Before I start I have a dead actuator (dead on the unlock side, lock works) on the Left/Rear door, that's not the problem here.
Starting yesterday, it seems that my central unlock has stopped working... key fob only disables alarm and button on dash (for unlock) does nothing. To actually unlock doors I need to use the key (from the outside) or open the doors via handle from the inside.
Any ideas?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old November 18th, 2014, 10:41 AM
either the ecu or you've lost a fuse. the actuator simply receives a + feed from the central lock ECU. it's unlikely all your actuators failed at the same time. focus on the ecu after confirming fuses are good
Mark Kellgren
KM4BOR
Old November 18th, 2014, 10:46 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Thanks Mark. Will check fuses tonight. Am I right to assume the "lock" and "unlock" sides are on different circuits?
~2008 GTI TSI
Old November 18th, 2014, 12:43 PM
I would check the header junctions in the main harness on the passenger side. Remove the kick panel trim and you should see a big harness wrapped in plastic/rubber. Cut away the plastic to expose the four or so header junctions in the harness and see if there are any broken wires or corrosion.
Fwiw I have seen a vehicle with five bad actuators.
Old November 19th, 2014, 10:35 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
pulled the fuse for the Central locking circuit, heard a click, replaced (non-blown) fuse. All was well. Everything worked as it should. Went outside a few hours later to get something from inside, no response from remote (other than lights flashing). I pulled the fuse again (not blown) replaced and still dead. I'm thinking its cold weather related...
~2008 GTI TSI
Old November 20th, 2014, 11:59 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Another update... Wifey drove it today, once it was warmed up, put the fuse back in everything (other than the known bad actuator) worked. Something being cold is definitely causing this. So weird.
~2008 GTI TSI
Old December 1st, 2014, 02:01 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Met up with Rovertek last week when I was on the island, he disabled superlock and auto locking upon reaching 4mph, it seemed fixed. But then it got cold the next day and was doing the same thing. BCU going bad is the current theory, thoughts?
~2008 GTI TSI
Central Locking Kits Advice? Landyman1 Defender Technical Discussions 18 November 21st, 2013 10:44 PM
Strange electrical problem... mongosd2 Defender Technical Discussions 9 September 28th, 2013 11:04 PM
strange electrical problem with lights docsd90 Defender Technical Discussions 1 June 15th, 2007 11:10 AM
Strange Fuel Pump Fuse Problem mhill Defender Technical Discussions 6 July 11th, 2005 04:23 PM
VERY STRANGE A/C problem Campbell Defender Technical Discussions 4 June 10th, 2004 11:29 AM
