Storage Box Lengths - Page 3 - Defender Source
Old December 1st, 2006, 07:44 PM
aloharover's Avatar
aloharover
Peter
1970 Series IIa 105
Originally Posted by DJ Menasco
Here's the direct link: http://www.defendersource.com/mod/toolbox/index.htm
The ltrue link is located on the main page for the D90 Source, not the fourm. In the header locate the "Custom Mods" link and click on it. It should be in the navagation links on your left at the very bottom.
DJ
Thanks. I never knew there was a website outside of the forum
Old December 1st, 2006, 08:15 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Chris von C
[/size]
Old December 1st, 2006, 08:32 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Old December 1st, 2006, 09:10 PM
aloharover's Avatar
aloharover
Peter
1970 Series IIa 105
need a head banging brick wall icon
Old December 2nd, 2006, 01:30 PM
johnlee
John Lee
Originally Posted by chrisvonc
Do you find the single handle strong enough for the box? I am assuming you unload the box before removal. Do you have any problems with the boxes moving around or does the carpet pretty much hold them fast?
The single handle is strong enough for an empty Troy Box, but definitely not strong enough for a full Troy Box. I think a Troy Box holds the equivalent of a Pelican 1650, and a Pelican 1650 full of tools weights a considerable amount. So I won't even try to lift a full Troy Box with the handle. My field set weighs a lot. I've never weighed it but it's a lot for sure.
The handle and LR oval are really there just for looks, to mimic the Genuine Parts shotgun boxes. The handle and LR oval don't serve any real or functional purpose. Even when I take out the Troy Boxes, I don't use the handle just in case. I the carry the boxes crate-style.
My Troy Boxes don't move at all. I secured them to the wheel wells using nutserts and threaded knobs. Knobs like this from McMaster:
http://www.mcmaster.com/library/20050823/2907T590L.GIF
I drilled four holes into the floor of Each Troy Box. I have a knob in each corner of each box.
I drilled corresponding holes into the wheel wells and crushed in nutserts. I used the nutserts because I wanted to be able to remove the Troy Boxes by myself and without someone else having to be inside the wheel well holding the nuts stationary while I turned the knobs. That would be a pain.
So far everything has held up really well.
Old December 2nd, 2006, 02:09 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
That is a really good idea John. I made the mistake of using fasteners, which as you pointed out takes two people to install/remove.
Old December 2nd, 2006, 03:40 PM
I can do mine solo (although I have no plans to remove them often). I had Troy put the hinges on the inner side of the box, and I can reach into the box with one socket and under the wheel well with another without problems. I just bolted mine down and dropped in some toolbox matt on the bottom. I did put a rubber seal on the lid edge, so the box is waterproof and doesn't rattle.
charles
Old December 2nd, 2006, 05:02 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
I went the "DIY" route:
http://www.dubai4x4.com/albums/albuo...0511.sized.jpg
http://www.dubai4x4.com/albums/albuo...0513.sized.jpg
http://www.dubai4x4.com/albums/albuo...0510.sized.jpg
Took the WHOLE area above the wheels and they fit EVERYTHING (including camping equipment for 2 people)
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old March 5th, 2007, 09:31 PM
Troys
Troy Smith
1995 D90 SW
Exclamation
I just completed another run of 32" long boxes. I have a few folks who have contacted me but I have others available for immediate shipment.
I also have a few 19" long boxes as well.
Please let me know if you have any questions.
Thanks!
Troy
tsmith@smithpackett.com
Old March 5th, 2007, 11:17 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
If only they had speaker pockets in them......
My oil line fix
My 100k stopped odometer fix
Old March 6th, 2007, 12:36 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
John's post confused me a little and I have a couple questions...
1. Do the boxes come finished black or have people been painting them after they receive them?
2. Is a nutsert the same as a Rivnut?
BTW, the boxes look great!
Old October 1st, 2007, 10:42 PM
Troys
Troy Smith
1995 D90 SW
I have ordered my material and will making another run of boxes. I currently have one 32" long box available that I would be willing to deliver to MAR to save someone shipping. I will be making all 32" long boxes this run with the exception of one 19" already spoken for. If you are interested in a box 32" long or 19" long, hinged either way, let me know so I can fabricate it for you.
Thanks again for all the D90 support!
Hope to see alot of you folks at MAR. Upper Field with "TEAM ROANOKE"
Thanks!
Troy J. Smith
Roanoke, Virginia
Old October 1st, 2007, 11:00 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Email sent!
Gary
Old February 21st, 2008, 06:05 PM
pcscharfe
pcdefender
D90/NAS 110
Question Any 32" boxes in stock?
Troy,
I have been enjoying my 19" box for a while now (here's a pic for anyone interested), but it looks like I am ready for an upgrade to a larger size. Do you have any 32" boxes made up? If not, I'd love to put my name on a list if you are considering another run in 2008. Thanks!
Paul
Old February 21st, 2008, 06:50 PM
I'd be up for a couple for my 110 as well>
Old February 22nd, 2008, 09:35 PM
Troys
Troy Smith
1995 D90 SW
Paul - Glad you are happy with your box!
I am sold out at the moment. I can begin another run next week. I like to try and have few folks interested before I commit to fabrication so the timing works out well. I will let you guys know when they are complete.
If anyone else is thinking about please drop me a line or pos here.
Thanks!
Troy
Old February 22nd, 2008, 10:11 PM
fleabus's Avatar
fleabus
Dan
None :(
Any chance you could do something like I proposed in this thread:
http://www.defendersource.com/forum/...ad.php?t=10749
I realize it is a departure from your specialty fender-mounted boxes, but maybe others would be interested?
-Dan
Old February 23rd, 2008, 09:13 AM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Email sent
Old February 23rd, 2008, 03:17 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I'd like a 19 inch box if it will fit next to one jump seat.
Old February 23rd, 2008, 07:50 PM
Troy,
Sent you an email> I want a 32 inch box.
Overhead Tuffy Storage Box dalesmith71 Misc. Chit-Chat 10 February 22nd, 2007 01:36 PM
Storage Box for the Holiday? Troys For Sale - Parts 4 December 16th, 2005 11:59 AM
Tuffy Storage Box RyanS For Sale - Parts 11 February 17th, 2005 09:43 AM
Tuffy Storage Box willtillery For Sale - Parts 4 September 18th, 2004 08:15 AM
Large Storage Box aschoent For Sale - Parts 0 July 21st, 2004 05:40 PM
