Steel Rims - Defender Source
Old September 20th, 2004, 12:08 PM
thug1313's Avatar
thug1313
Brian Ellis
Sold it!
Question Steel Rims
A buddy of mine gave me 5 Wolf steel rims (NATO, I think). I was interested in replacing my alloy rims and also needed new tires anyway. Now I can do both at once. The rim dimensions are stamped 6.5j x 16 x 20.6. Although I understand all 3 aspects of those numbers, I don't know what size tires to order. The rim by itself fits nicely on the hub, so offset isn't a problem.
I have a pristine Bridgestone All terrain as my spare on the stock alloy rims. It is LT265/75/R16. I know what all those numbers mean too. What I don't know is, will that tire fit on that rim? Any clues?
Brian Ellis
Old September 20th, 2004, 12:53 PM
redrover
Guest
Posts: n/a
The rims are 6.5inches wide x 16inches . You can put your 265/75 -16 on them or even a 285/75-16. The 285s are 33inches tall and the 265s are 31inches tall. 90s look really good with the 285s and if you wheel a little, you will appreciate the added clearence. JP
Also some folk like a 255/?-16 tire
Old September 21st, 2004, 10:44 AM
januconn92's Avatar
januconn92
Jan Jurgielewicz
97 D90 #1477 Green ST
The 255's are sweet, they fit the NATO rim nicely
Old September 21st, 2004, 10:59 AM
KeithD
Keith Duckett
90 V8 Import
255/85s that is - 285/75 is getting a bit fat for 6.5J rims.
Old September 22nd, 2004, 06:57 AM
Kev Baldwin
Kevin Baldwin
2.4 Tdci 110 Utilty Wagon
Note, Wolf rims come in tubed and tubeless versions.
Old September 22nd, 2004, 12:00 PM
thug1313's Avatar
thug1313
Brian Ellis
Sold it!
I assume they're tubeless, because they had valve stems installed in the holes from the previous tires. Correct?
Brian Ellis
Old September 26th, 2004, 03:01 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Not always so tubed type rims will have tubed stamped on the rim and tubeless have a sort of lip slightly inboard ofthe edge of the rim, helps keep the tyre bead in place.
Mike Hammond
rims
Need steel rims Method PHX Wanted 0 November 30th, 2005 04:21 PM
Super Swampers with steel rims d90Monkey For Sale - Parts 7 October 29th, 2004 04:36 PM
5 white steel rims and 4new michelin 205s draaronr For Sale - Parts 6 September 24th, 2004 08:43 PM
steel rims NATO or Safarigard stanman Wanted 4 March 23rd, 2004 04:43 PM
Wanted 110 Steel Rims Glenn_Guinto Wanted 0 October 1st, 2003 12:52 PM
