Steel or Synthetic? - Page 2 - Defender Source
View Poll Results: Steel or Synthetic Line?
Steel 1 3.70%
Synthetic 26 96.30%
Voters: 27. You may not vote on this poll
Old May 3rd, 2016, 04:00 PM
IMO.... If the "plan" is just to buy a cheap and slow winch that does not take a lot of cable, then who cares what rope it has on it. You are not planning to use it other than a once in a lifetime emergency. If you start wheeling where you actually use it everyday, you will go insane waiting for the stupid thing to spool in and move on to something decent. It is then that you will want synthetic. You are pulling line a lot and doing complex pulls.
Old May 3rd, 2016, 04:33 PM
Unless you winch for a living or are winching in a race, gauging a winch by its "speed" is ridiculous. No safe recovery is made by rushing anything.
Old May 3rd, 2016, 04:49 PM
If you winch a few times a day, you will go insane with a slow winch, at least in my opinion. I would much rather spend more time driving than waiting for a winch. It does not need to be racing. Just recreational wheeling where using a winch is commonly required. If that is not the type of wheeling you do, the one linked above should be a great choice. Spend the extra $20 on the nice cover.
Old May 3rd, 2016, 05:21 PM
LR Max
Thomason, Max
1973 Series 3 109
Slow winches are usually cheap. Enjoy it when the solenoids fuse together...closed...and the thing is winching in uncontrollably. From experience, I can tell you that is fun scrambling to find a wrench to disconnect a battery. Oh and you can't just cut the cable. Although it does make for fun fireworks in ones face. But totally let your buddy do that, because then you can give him crap for it.
Also slow winches are a huge cause of trail traffic jams. I remember when tellico was open, it would take a fast winch to get a rig up Slickrock in about 10 minutes. A slow winch would require 45 minutes.
Fast "off the shelf" winches such as the 8274 or XD9000 or 9.5 (or whatever) really aren't like, lightening fast. We are taking 5 ft/min instead of 1 ft/min or whatever. Fast enough to get you out of trouble, but not fast enough to get you hurt, unless you aren't paying attention. The longer you are winching, the longer you are testing the limit of the duty cycle and the longer you are hanging out there.
My personal winch is a M12k. It is SSSSLLLLOOOOOOOWWWWWWWWW. Under heavy load, I wonder if it is even moving. So then half way through a hard pull, I gotta stop...hanging there...waiting for everything to cool off. A 8274, I would've been outta there and down the trail (I've got an old 8274 on my bench that I'm gonna build up with new components). Yes the M12k has been a beast, but I've learned I can sacrifice some unneeded capacity for needed speed.
As for synthetic. My rope is 15 years old. It has picked up at least 3 discos and put them back on the trail. Lord knows how many times its saved my skin. No idea why anyone wouldn't go with synthetic. So much easier to handle and deal with.
Old May 3rd, 2016, 05:59 PM
TMWTP's Avatar
TMWTP
Jon
1989 One Ten
I would never consider running steel after using poly line. Safer, easier, lighter. And for the comment about getting it wet, the original application was ship mooring.
Sent from my HAL 9000 using Tapatalk
'14 F250 dd tow rig
'17 Discovery (wife's dd)
'88 110 under the knife
'12 Rockware 3-seat rock buggy - FOR SALE!
'13 LR4 - FOR SALE!
'83 110 - FOR SALE!
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
Dynaflex Synthetic Winch Lines Starting @ $280.00 RedRhinoProducts The Vendors Loft 1 November 4th, 2004 09:07 AM
Which synthetic rope revisited: snuffer Defender Technical Discussions 0 June 14th, 2004 07:59 PM
Which synthetic winch rope is... howellm70 Defender Technical Discussions 17 May 31st, 2004 01:57 PM
AMSOIL Synthetic Products javelinadave The Vendors Loft 0 January 5th, 2004 05:13 PM
