Stealership Mishap with Truck - advice needed - Defender Source
Old June 19th, 2016, 11:53 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
My daily driver is 2500 Chevy. Decided to use one of the free oil change / tire rotation services that GM gives you when you buy the truck so I could do other stuff over the weekend.
Pick up the truck in the service drive and proceed out on the main road. Immediately notice something is wrong; steering is sluggish and truck seems to be pulling.
Pull over and the passenger side front wheel is about to fall off. Lugs are barely on; finger tight at best.
Call the service guy and he gets a tech out there with a floor jack and electric impact.
Truck drives normal and I didnt have time to take the wheel off and inspect the studs but now I am wondering if I should be worried about those studs given the strain that they were put on and the long term implications. I know if something happens down the road, they wont own up to it.
Thoughts?
Old June 19th, 2016, 12:11 PM
You'll be fine. Long term a loose wheel can wear away the studs. But from the driveway to the main road, you shouldn't have any issues a visual inspection won't reveal. You should remove the wheel and have a look, but you should be fine.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 19th, 2016, 01:20 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I had a similar situation with the Harley dealer. Could have turned out much worse.
Got my Softail back from a full service. Was riding through downtown on some of the bumpy patch work on the pavement when the front end started acting funny.
The cap at the bottom of the fork tube that holds the wheel in place had fallen off. The result of a failure to tighten them.
Black Rhino Lives Matter
Old June 19th, 2016, 03:49 PM
Had a brake caliper bolt come off after a brake service at a BMW motorrad dealer. If you didn't die discovering the problem you'll be ok!
Old June 20th, 2016, 02:15 PM
97-D90-736
Nick Vogel
Thanks guys for the feedback. The studs were fine.
I am almost comforted and terrified to hear that this stuff goes on everywhere and on critical areas.
Only solution is to take minute and walk the car before getting in.
Old June 20th, 2016, 02:54 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I had the same thing happen a couple of months ago with my Jeep Wrangler... brought it in for an oil change and started driving away.. it felt weird right away, but it was in an crappy paved parking lot, got another 100ft and got out to inspect and found them to be finger tight. I told the service manager, who called the tech, who came running out to fix it. The Jeep lease was ending a couple of weeks later so I didn't bother to complain anywhere as I wasn't going to be using the dealership anymore.... It's scary to think that it could happen to someone who doesn't bother to say anything and they could lose a wheel on the highway.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old June 20th, 2016, 09:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I had the opposite happen. Went to swap a motor mount on the Burb a couple months ago and the wheel lug nuts must have been at 200 ft/lb. I had the extended breaker bar and then a cheater bar on that and still needed a bunch of weight to get them loose.
And I am so sick of my Chevy dealer. I've been there 1x month for the past 6 months to try and fix an issue with the front end and they still can't get it right. It's going to an independent next time. I would have thought a Suburban would last over 100k miles and not need a whole new front :rollseyes:
Old June 20th, 2016, 09:48 PM
87 D110 (Ruby)
funny....happened to me on my AMG a while ago...no long term issues like everyone else. So I expect by now you realize it will be all good judging by majority rules.
advice
200tdi timing mishap tomaco1 Defender Technical Discussions 10 November 2nd, 2010 06:11 AM
I avoided a major mishap today ...saved by one lug nut.. pmd Misc. Chit-Chat 12 May 18th, 2009 10:37 AM
stealership tells my wife....... mjekogian Defender Technical Discussions 10 March 14th, 2009 08:18 AM
Starter replacement mishap bjenk Defender Technical Discussions 2 May 26th, 2007 12:32 PM
Gwinnett, GA Stealership gtg067i Misc. Chit-Chat 13 December 15th, 2005 02:43 AM
