SS oil cooler lines - Defender Source
Old August 14th, 2014, 01:49 PM
pdz's Avatar
pdz
paul tj deasey
1994 D90 - #795
SS oil cooler lines
I have heard ECR makes the best braided stainless steel oil cooler lines, however they apparently don't sell them anymore. Does anyone know of anyone that makes 100% SS braided oil cooler lines with no rubber or can point me in the right direction.
Old August 14th, 2014, 02:05 PM
It still amazes me that this is difficult to find - which is not a good thing! Trailhead4x4 is your go-to - ECR doesn't do mail order. Let me know if Trailhead doesn't come up in the first few results if you google "1994 oil cooler lines" because they do when I search. Need to make sure this stays near the top somewhere.
http://www.trailhead4x4.com/30464.html
http://www.defendersource.com/forum/...ead.php?t=5135
http://www.defendersource.com/forum/...ad.php?t=38794
Old August 14th, 2014, 02:26 PM
pdz's Avatar
pdz
paul tj deasey
1994 D90 - #795
Thanks a ton. I found some online but want to get the correct ones
Old August 14th, 2014, 02:32 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Take a photo of your connections at the radiator and send it to trailhead 4x4 and they will be certain you get the correct adaptor if needed.
Old August 18th, 2014, 03:33 PM
pdz's Avatar
pdz
paul tj deasey
1994 D90 - #795
Emailing pictures... great idea. Thanks
Old August 27th, 2014, 01:03 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Dragging this back up...
I'd be thrilled to get a set for the '97 especially as long as the engine is out anyway.
I've e-mailed and phoned Eric with no reply.
Does anyone know if he's just out of the shop these days?
Old August 27th, 2014, 01:56 PM
kgottehrer
Kevin Gottehrer
1997 D-90 SW
Eric is still there. He sent me some SS oil cooler lines for my '97 a few weeks ago, so I would assume he's just out of the shop
Old August 27th, 2014, 03:59 PM
UnfrozenCaveman
Keith Armstrong
Various
Thanks, I'll keep trying.
KAA
Old August 27th, 2014, 04:43 PM
pdz's Avatar
pdz
paul tj deasey
1994 D90 - #795
Eric is out of town for 2 weeks, he was going to Colorado. He sent mine out the day before he left. He was having more sets made, for when he returned
Old August 27th, 2014, 05:52 PM
ymc226
Lawrence
1995 D90 SW NAS
I replaced my oil cooler lines with those from Eric at Trailhead. My understanding is that these are regular lines that are covered with stainless steel to make them less prone to failing and re-routed so they don't run as close to the hot engine. Unfortunately, they also can fail and cannot be inspected due to the stainless cover.
When should they be replaced? After 75K miles? After 5 years?
Old August 28th, 2014, 04:22 PM
UnfrozenCaveman
Keith Armstrong
Various
I just talked to Eric...he's out west playing and will be back in the shop on 09-Sept.
All is well, remain calm
@ Lawrence...I'll be darned if I know the answer to your question.
I'm replacing the o.e. lines on our '97...yes, they're a little weepy and they've only got ~68,XXX miles on them.
KAA
Old November 5th, 2014, 11:52 AM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
Just a psa I was over at my mechanic and they had a 90 there for a oil line failure luck for him he put it out with dr pepper and his car was not up in smoke
Replace your lines if you have not
BUY SOME SHIRTS ---> OverthROW
BUY SOME HATS --->
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Best price on Oil Cooler Lines? bd90 Defender Technical Discussions 9 May 19th, 2004 10:44 AM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
