Springs... While I'm at it? - Defender Source
Old April 12th, 2004, 12:55 AM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Replacing springs and shocks next weekend, hopefully. What other things should I do as long as I'm under there?
(and NO Hippert, putting 4" lift is NOT an option. )
Old April 12th, 2004, 01:04 AM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Wicks had a cool thing recently about the replacement spring pad retaining bolts. I think they're off of a D2 IIRC.
You might want to look into upper and lower spring retainers too. If you do any hard-core off-camber stuff retained springs are superior to cones IMO and this is an easy time to install them.
Michael Slade
www.tawayama.com
Old April 12th, 2004, 08:50 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ken, are you sticking with the same tires? I would go with a set of OME's Something similar to CVC's setup...
Legend in My Own Mind.
Old April 12th, 2004, 09:58 AM
loykd's Avatar
loykd
Ken Loy
Going with the HD OME setup and same tires, Randy.
Mike, Is this the discussion you were talking about: http://www.defendersource.com/forum/...1548#post10486
I don't do off-camber stuff. Not a lot of big rock formations out here, but plenty of mud. Much of a need for these retainers for "tame" riding?
Old April 12th, 2004, 11:05 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ken, sounds nice.. did you get that RW bumper too? Are you getting longer shocks also?
Old April 12th, 2004, 12:13 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Tame riding? Honestly, no. If your springs never pop out of their perches, then you don't need to retain them.
The spring pads are pretty cool though, and you can't put them in unless you remove the spring. Now is a pretty good time to do that.
Michael Slade
www.tawayama.com
Old April 12th, 2004, 02:27 PM
Axles, driveshafts, tires and engine.
oh wait thats on my list to do someday.
Retainers you may or may not need them, only going out with your new setup will tell. I didn't put the cones up front until I changed the shocks and the springs kept falling out of there perches.
Old April 13th, 2004, 12:00 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I just picked up a set of OME springs while at work. Talk about funny looks in the office as I walk through with two boxes of springs. Anyway need any help putting them on?
Jimmy Buffett
Old April 13th, 2004, 12:40 AM
loykd's Avatar
loykd
Ken Loy
Tyler, Maybe... I'm doing mine either Sat or Sunday, probably in SoMD. Did you want to do both at the same time? If so, I'll have to see about access to the auto shop for you.
Old April 13th, 2004, 01:22 PM
flippedrover
Tyler
'94 D-90
Hmm.. I'm planning on doing mine friday. From what I've been told it should take me about a day. Let me know what day you end up doing it and I'll pitch in if needed.
Jimmy Buffett
Old April 13th, 2004, 01:28 PM
It took me about an hour per shock to change in the front and that included taking out the spring, I just took the wheel off and dropped the axle to the ground then jacked up on the slider until the spring fell out, oh yeah undo all the bolts on the shock first.
Old April 13th, 2004, 01:56 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Ken and Tyler -- if you need help or a place to do it, let me know.
Tony
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
new springs? scoloco Defender Technical Discussions 4 April 5th, 2004 06:08 PM
OME springs! TwisteD90 Misc. Chit-Chat 5 October 2nd, 2003 06:16 PM
