Speed Bleeders - Defender Source
Old January 31st, 2011, 12:35 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Speed Bleeders
I have heard some good reviews on Speed Bleeders. I need to bleed my brakes soon and was wondering if anyone here is running them.
Is the correct size M10x1.0 or 3/8"x24?
Old January 31st, 2011, 12:26 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I have not used them myself, but a friend of mine swears by them. He has them on both of his BMW's and absolutely loves them. I would be interested in knowing the correct size too as I plan on getting them for mine in the near future; although, I believe mine may be a little different being a 110 and having the rear disc conversion using Disco I rear calipers...
Old January 31st, 2011, 02:34 PM
ini88's Avatar
ini88
Daniel Marcello
Yeah I have heard all positive reviews about them. I work on my truck with people and alone and when I work on it alone these would come in real handy. I would imagine your DI calipers come with the same thread size bleeder as Defender and even RRC. Those trucks seem to have most things in common below the belt. I may get a set and try them out.
Old January 31st, 2011, 03:59 PM
with the amount of time you spend off road ... I'd make sure you have good dust caps ... corrosion jamming up that ball and spring might not be fun!
Old January 31st, 2011, 04:25 PM
ini88's Avatar
ini88
Daniel Marcello
You are right. I could see that spring rusting up nice and quick with some of that Pine Barrens water.
Old January 31st, 2011, 04:27 PM
alien blood ...
Old January 31st, 2011, 09:29 PM
michael67's Avatar
michael67
Michael White
110 Tdi
I have Speedbleeders in my old CJ, and they seem to work fine. However, now that I bought an Eezibleed system, I see no reason to replace the bleed valves my Defender. I'm much happier with it that with the Speedbleeders.
Old January 31st, 2011, 11:12 PM
ini88's Avatar
ini88
Daniel Marcello
That is nice. I just checked out a video on it. looks so simple running off the tire pressure. Brakes are easy, but a super easy one man job would be nice.
Old January 31st, 2011, 11:32 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Check out a company called Phoenix I believe is what they are called saw proof in the pudding about them on a car show called Gearz. Might find the episode on Youtube. Basically it lets you reverse the bleed process by letting you have the bubbles come up and out to the reservoir. And is designed as a one man job. Still need to start at the furthest wheel though.
Old February 1st, 2011, 08:57 PM
michael67's Avatar
michael67
Michael White
110 Tdi
And it's easy enough to convert it to use pressure from an air compressor. Just a couple fittings (1/4" NPT?) from Harbor Freight does the trick.
Old February 1st, 2011, 11:36 PM
Another popular one is the Motive Power Bleeder http://www.motiveproducts.com/
bleed
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
AC Fan Speed Knob Missing...Argh! boshea Defender Technical Discussions 7 February 17th, 2006 09:55 PM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
speed sensor wiring rcork Defender Technical Discussions 2 July 27th, 2004 09:44 PM
