Spacers for Boost on ROW 90 - Defender Source
Old May 7th, 2015, 02:11 PM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
Is there a specific size wheel spacer needed for Boost's on an ROW 90? Will 30mm do the job?
Thanks!
Old May 7th, 2015, 02:34 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
30mm will work to clear the drive flange if that's your concern, but the spacers are designed around the longer alloy wheel studs so you won't have the appropriate amount of thread engagement on the wheel nuts that hold them.
-Ash
Geared Restoration Co.
352-572-3236
Old May 7th, 2015, 02:42 PM
ATX_D110's Avatar
ATX_D110
Victor
Ash - Thank you. Is there a specific or more ideal size spacer that will still clear the flang and provide enough thread for boosts?
Old May 7th, 2015, 03:00 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Don't forget to eliminate the locking washer rings and use loctite instead of it to hold the flange bolts in place. Even with spacers and the correct length studs you may have the flange bolt heads hit the inside of the alloy rim preventing you from mounting them. This is only the case on the fronts and not the rear and is dependent on the thick flanges. If you put a US disco axle swap on then you shouldn't have any issues.
You could get creative and take off some of the inside of the alloy rim or shave down part of the flange bolt heads but I wouldn't recommend those methods.
Old May 7th, 2015, 04:29 PM
Ash's Avatar
Ash
Ash Heller
The RHD guys can't just swap front axles since anything you'd find in a junkyard would be LHD. The thing to do is swap CV's, stub axles, rotors and drive flanges from a Disco (or RRC if you want vented rotors, although then you need new calipers as well) into your RHD swivel ball housings to be set up for alloys, Wolfs, and/or spacers the proper way.
-Ash
352-572-3236
Old May 7th, 2015, 04:39 PM
ATX_D110's Avatar
ATX_D110
Victor
Let me rephrase it this way. The pic is my current set up for wheels with spacers. When I swap out with Boost, will the current spacers suffice?
Old May 7th, 2015, 05:39 PM
Boost wheels in Texas? What's next, skinny chaps? Sideways wearing cowboy hats?
Old May 19th, 2015, 09:33 AM
ATX_D110's Avatar
ATX_D110
Victor
Bump: Still looking
Old May 19th, 2015, 10:03 AM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I have the same wheels as you...and as far as I can tell the Boosts are just a slight design pattern difference....the backspacing and other dimensions are the same...so the 30mm that we both run should not be an issue...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
110 ROW 2nd Row seat Cajun For Sale - Parts 3 March 27th, 2015 05:51 PM
Spacers for Boosts on ROW 110? atpick Truck Build-up's & Restores 3 February 17th, 2013 12:53 PM
WTB Lug Nuts and Spacers for Alloy Boost Wheels on D110 ('93) silverlight Wanted 22 October 18th, 2011 08:58 PM
ROW Middle Row Seats Wolf Fabrication For Sale - Parts 10 May 24th, 2011 06:00 PM
wheel spacers krisp For Sale - Parts 15 November 30th, 2004 11:03 AM
