Solar Generator (DIY Goal Zero Yeti) - Defender Source
Old June 13th, 2015, 07:28 PM
As many of you know my daughter is an insulin dependent (type 1) diabetic. If her insulin gets warm it stops working. Today I built a solar powered generator. It will if necessary power an ARB 12v refrigerator if we have a prolonged power outage at home. It will also work as a power station for base camping trips. In a nut shell it's a Goal Zero Yeti 1250 for less than a third of the cost.
Here is the breakdown. I purchased these three dustproof containers at Home Depot ($98 OTD special) I only used the bottom wheeled box which by itself was $60.
Next up was selecting the battery. I wanted something sealed so I went with a 70ah AMG battery from Auto Zone. I considered Optima but from my research the new ones lack quality and were WAY more expensive. The charge controller is a Morningstar 10amp model from Amazon ($56).
I went with Blue Sea for the fuse panel, master switch, 12v outlets and the USB outlet. Amazon had them but they were about 10% cheaper from a marine shop on EBay.
Here is the almost completed interior. I still need to cut some stiff foam to hold the battery in place.
The RENOGY 100 Watt 12v solar panel was purchased from Amazon for $150. I also bought with it a 25 foot cord and cut it in half so I could have a positive and negative 12" section with the correct connectors for the panel. On the box side I went with an easier to connect/disconnect plug type.
All the wiring is 10 gauge except for the wiring to the USB. Goal Zero wanted about $1600 for their unit plus a few hundred for the solar panel. I'm in it for less than $500 and am very happy with the final results. The rolling box weighs about 50 pounds and the panel weighs just a few pounds. I still need to make some folding legs for the panel and sew up a neoprene sleeve to store it in.
Old June 13th, 2015, 07:46 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Good Stuff!!
Old June 13th, 2015, 07:53 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Well made, peppers will be envious. When you upgrade go with a folding panel.
I just found one of those little honda inverter gensets on the road side, guy said it doesn't run. Got it home and Checked the oil. NONE in it, topped it up fresh gas and off it ran.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 13th, 2015, 08:30 PM
RBBailey
RBBailey
1965 IIa
Awesome. Looking forward to putting mine together. Good ideas here.
Project:
1965 IIa SWB
Old June 13th, 2015, 10:01 PM
TMWTP's Avatar
TMWTP
Jon
1989 One Ten
Interesting. I have a type 1 kiddo as well and just found a deal on a goal zero yeti 1250 on Optics Planet to run my ARB fridge. Tested it out last week and it worked very well. I am going to add two more batteries and an array of panels to my enclosed car trailer. Can't wait to hear your test results!
'14 F250 dd tow rig
'17 Discovery (wife's dd)
'88 110 under the knife
'12 Rockware 3-seat rock buggy - FOR SALE!
'13 LR4 - FOR SALE!
'83 110 - FOR SALE!
Old June 15th, 2015, 03:29 PM
vasily's Avatar
vasily
Vasily
Nice work!
Old June 15th, 2015, 03:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Subscribed! I'm planning on something similar. Great stuff!
Old June 15th, 2015, 04:21 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Dave,
Very good work! Thanks for sharing!
Old June 15th, 2015, 05:03 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Very cool.
RDavisinVA
Old June 15th, 2015, 09:48 PM
Nicely done.
Old June 15th, 2015, 10:30 PM
87 D110 (Ruby)
Wow....great job mate
Old June 15th, 2015, 11:21 PM
Nice job!
Originally Posted by pendy
I'm here for the D's
Old June 17th, 2015, 02:26 PM
The experiment starts this morning and this should be a good test. Today's forecasted high...... 113F (45C) with an evening low of 85F (29C)
Old June 17th, 2015, 02:56 PM
Bill Larson
Bill Larson
Heck put it in the sun! Even I would hang out in your yard with that heat. Your yard is set up very nice!
Old June 18th, 2015, 04:39 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Waiting to see how this works out. Great job Dave. I picked up a set of panels at expo east and still need to try them out. This may be the kick I needed.....
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old June 18th, 2015, 04:53 AM
Definitely make the test harder by putting arb in the sun!
Old June 18th, 2015, 11:51 AM
This turns out to be a great week to test things out. Record heat (114F) yesterday and hotter (115F) today. Here is the data thus far.
Battery started the test at 13.0v at 10:00a yesterday and the fridge set and pre-cooled to 32F.
07:00a this morning the battery was at 12.4v and the evening low was 82F
08:30a I lower the t-stat to 30F.
Stay tuned for further updates!
Old June 18th, 2015, 12:23 PM
Taste test the beer!
Old June 18th, 2015, 06:33 PM
115F on the patio, the fridge is 27F degrees and the battery is 100% topped off. I'm calling this a successful project.
Old June 18th, 2015, 06:42 PM
roverman2010
1985 LR 90 200Tdi
Now all you need is a 110 volt inverter and a cooling fan, Good job
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Yeti Tundra 250 josh-man The Flea Market 33 September 6th, 2014 04:32 PM
DIY Solar Panel building... rdavisinva Misc. Chit-Chat 11 October 17th, 2013 03:45 PM
Los Angeles Sighting - "Il Yeti" specops1526 Misc. Chit-Chat 0 October 20th, 2008 01:47 AM
Solar question again. Kinda long kellymoe Defender Technical Discussions 3 March 22nd, 2004 04:48 PM
Solar Power kellymoe Misc. Chit-Chat 9 March 11th, 2004 07:38 PM
