So if Engine swapping isn't legal, why are 'gliders" legal? - Page 3 - Defender Source
Old June 12th, 2015, 06:52 PM
carlosz's Avatar
carlosz
Carlos
I am a va licensed emissions inspector, amongst many other technicalities of epa regulations, it states.
1-it is unlawful to install a larger displacement engine than the vehicle's original equipment
2-it is unlawful to install an older model year engine than the chassis model year
3- it is unlawful to install a heavy duty engine in a light duty chassis
4-it is unlawful to remove or render inoperable any part of the emissions system of a vehicle
5-any replacement engine must be epa certified.
6-any replacement engine must have all required emissions equipment installed and operating per vehicles' emissions label.
personally I think it is easier to ask for forgiveness than it is to ask for permission.. thus do the swap
and file with epa, don't ask epa to allow you to do the swap....
Old June 13th, 2015, 12:25 AM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
Originally Posted by Ren Ching View Post
Why just look at it? Shit man, light it up!
Bob Marley drove a 109, mon.
Legal here July 1st my friend.
Old June 13th, 2015, 12:35 PM
Chip's Avatar
Chip
Andrew
That's very interesting about the rule regarding the displacement of the engine. So those LS swaps are illegal, as are putting a 4.6 Rover V8 in a NAS Defender. So mine could actually be the first legal engine conversion in a NAS Defender...-> smaller displacement, newer model year, same class (light duty), all required emissions equipment & produces lower emissions, same fuel type, and EPA certified. Pretty rad.
Old June 13th, 2015, 12:58 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
If it's illegal, it must be fun. Why else would it be illegal. Lol
Black Rhino Lives Matter
Old June 13th, 2015, 01:00 PM
Well that takes every Chevy/Ford/Mopar big block, crate engined hemi powered hot road off the road.
Suppose there is always supercharging.
Old June 13th, 2015, 01:49 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Then there is this story. The car manufacturers want to make it illegal to work on your own vehicle.
https://www.yahoo.com/autos/s/gm-for...160000229.html
Of course this will only affect newer vehicles with computers.
Old June 13th, 2015, 01:55 PM
I believe the spirit of the law is that you shouldn't remove or alter the engine of a car so as to circumvent the emission standard. It makes sense of course. Who would put an engine in their car that would fail state emissions testing? Who would alter or remove emission control provisions that would fail state emissions testing? Only a fool, that's who.
So any pre OBD IV vehicle gets a bye more or less as long as they can pass the tailpipe CO test. In that regard anything goes as long as you can get it past The Man.
Old June 14th, 2015, 10:15 AM
A fool with historic tags, and clogged cats, maybe...
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 14th, 2015, 04:10 PM
carlosz's Avatar
carlosz
Carlos
I raised the question and concern regarding japanese import tunners and engine swapping..ie prelude drive train into civic body....
instructor responded with (grey area) "althou it is a larger displacement engine for which the chassis is is not designed as long as all emissions components which the civic chassis is supposed to have, and there and in working order, the vehicle can be tested, if it passes well, if it does not the owner must address the issue as to why it failed.
the prelude engine may have components which the civic chassis does not list on its label, example EGR valve
if such is the case the inspector cannot fail for extra components but can fail for lack of components as it is
tampering."
addinng turbos, superchargers, blowers, stroking, boring or other means of power adders is not illegal so as long as emissions systems components remain installed and operable"
my way of looking at it ... it is grey area...so technically for inspection purposes we can switch to a 4.6 as long as we tell the inspector we still have what the label says we should have in there.
it is a very long 20 hrs class it is broken in four segments one of then deals with all kinds of legalities, swaps customs, upgrades etc. basically you can do anything so as long as you keep it "legal"... wink wink...
Old June 14th, 2015, 07:07 PM
Originally Posted by transientmechanic View Post
Well it is, by the letter of the law...
He probably just doesnt understand that the USA has literally millions of unenforceable regulations that are largely ingnored.
However, not to play devils advocate but following Will H's fight with the CBP and the subsequent egg on their face, it wouldnt be a stretch to imagine CBP calling their friends at the EPA and nudging them about this regulation......
Part of the reason that case fell apart was that EPA declined to get involved. They have no enforcement staff to track down engine swappers. Some of the key desks/positions @ EPA are filled by contractors, ie not even govt employees.
engine
I'm Sure "Money Pit" isn't an original description :: 1997 Land Rover Defender 90 ST Nashville Defender & Series Truck Registry 1 July 10th, 2015 02:45 PM
Icon4x4... why isn't someone doing this with Defenders? TravelerBT Misc. Chit-Chat 26 September 11th, 2012 06:42 PM
Sorry Fellow '97 Owners, Our Defender Isn't "True"... jordan0527 Misc. Chit-Chat 18 August 5th, 2008 08:03 PM
Why oh why (aka broken CV joint) bharris Defender Technical Discussions 39 January 22nd, 2008 12:08 AM
WHY WHY WHY am I blowing through suspension bushings? KevinNY Defender Technical Discussions 27 September 13th, 2007 02:29 PM
