Small radiator suggestions - Defender Source
Old December 8th, 2014, 09:29 PM
I'm looking for ideas/suggestions for small radiators for my EV project. My motor and inverter are both water cooled and initially I planned to use one circuit to cool both. I have since learned that the inverter likes to run cooler than the motor and will need two circuits. That and a redesign of my front battery box leaves me looking for two small radiators to fit in the series engine bay (say 24" wide with room for the ports), but leave room for the battery box (about 7" below the slam panel - I can extend about 2" above it like a stock radiator, leaving about 9" tall radiators). So ideally a 12"x9" radiator.
These would be ideal if they were less tall since they have integrated tanks and filling points.
http://www.frozenboost.com/water-to-...or-p-1062.html
I could put them side to side and route the lines to each side. But they are too tall by about 5"
The other way would be to put one in front of the other. I already have one of these
http://www.brightonracingproducts.co...ass-10-004.htm
and two of them would work except they would need to be staggered to allow access to the ports, which I don't really want to do.
I could also get one of these
http://www.ebay.com/itm/BAR-PLATE-FU...-/400386557228
Which would allow me to have those ports go to the side, but it's pushing the width wider than I'd be comfortable with.
These are probably a better fit although I'm not keen on the push on connectors (can't really explain why)
http://www.ebay.com/itm/Air-to-Water...-/140584269021
And this setup require reservoirs which are more things to find room for, so I'd prefer integrated tanks.
Do you have any better ideas? Know of a source for 12x9 radiators or something close?
tia
charles
Originally Posted by pendy
I'm here for the D's
Old December 9th, 2014, 01:32 AM
How about motorcycle radiators
Old December 9th, 2014, 07:42 AM
Or heater matrixes? Lots of those out there in the size you need
Old December 9th, 2014, 08:05 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I was thinking the same thing.
Old December 9th, 2014, 08:21 AM
Yeah motorcycle and Atv radiators were one of the first things I looked for. They all seem to be every specific shapes and not nice little rectangles. I will try them again before giving up.
I will search for heater cores. With a custom frame they might be the ticket.
Sadly large computer coolers are use in size - I'm a bit wary of them being able to handle the automotive environment though.
Old December 9th, 2014, 09:33 AM
I love your thinking out of the box. Spectra premium has an entire on line catalog of heater cores. Most car and truck heater cores are smaller than you are looking for. There must be more companies out there with similar sites.
Try these: http://ecat.spectrapremium.com/prod/heaters/99425
You also want to keep the inlet/outlets pretty generic unless you are willing to modify to your needs.
Old December 9th, 2014, 10:12 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
Suzuki DRZ400 radiators
Old December 9th, 2014, 10:15 AM
what is the max thermal output due to loss?
Old December 9th, 2014, 10:16 AM
Look for an early GoldWing radiator. They are made to fit between the two front frame members so they are tabbed and rubber mounted. The fan assembly mounts to the back. Used to ride one so i think it's a good fit.
Old December 9th, 2014, 10:59 AM
Remember I am height constrained. Without even trying to lookup the dimensions (the other problem with bike radiators) I can tell those gold wing ones are too tall.
Ed, don't get all technical on me. I need the best cooling capacity I can fit in the space
Old December 9th, 2014, 11:07 AM
I kept within the dimensions you mentioned. But my concern about heater cores v Radiators is that the latter is probably built a little tougher and better able to handle road debris that gets kicked up into the air stream.
Custom aluminum might be the best way forward. Especially if you need to add a fan and shroud.
Old December 9th, 2014, 11:38 AM
All you need to do is have a radiator shop either rotate or relocate the filler neck. I think you should stick with looking at brass motorcycle ones.
Old December 9th, 2014, 01:34 PM
Hahah. Well, the thing is that your thermal needs may be much smaller than you think.
Assuming a 30% efficiency for a gas engine and 90% efficiency for a 3 phase AC motor @ 60hp, the equivalent gas engine radiator would be one appropriate for a vehicle making 20hp.
Also doesn't the electric motor only dissipate this heat under full throttle? I'm assuming at idle it makes 0 heat.
To me this means you could get away with using a single radiator from a liter motorcycle and still have enormous amounts of leftover cooling capacity. Also you could probably drastically improve the cooling efficiency of a smaller radiator with an electric fan and a dedicated coolant pump.
Also I disagree that copper/brass is always better than aluminum. The core design of the radiator is much more important than the material that the radiator is made of. I've never seen a high performance race/drag car use a copper/brass radiator, except maybe in the 70's?
Old December 9th, 2014, 01:41 PM
Brass cz it's easier to find a shop that can rework it, not due to thermo qualities.
Old December 9th, 2014, 01:55 PM
transientmechanic
1972 SIII
Get a custom one built - someplace like Ron Davis can probably build two cooling circuits into one assembly for you to make packaging easier. It won't be cheap, but custom conversions never are.
Old December 9th, 2014, 02:10 PM
An electric motor does not idle..... Heat production will be based on current draw, which is proportional torque output.
Old December 9th, 2014, 04:25 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
08+ klr might be a good size I can check my bike when I get home if you would like.
Old December 9th, 2014, 05:48 PM
Dave, that would be great. no bigger than 12" wide, 9" tall for the tank size, (cap can extend).
On the material, I am actually partial to aluminum, simply because the devices being cooled are aluminum and I think it makes sense to keep it one material. But I'm not ruling out copper or brass.
Ed is right that I should be able to calculate the cooling required. The problem is there are too many unknowns. Let me list at least what I do know, and what I think needs to be taken into consideration.
1. Total volume of coolant. Unknown until I can make decisions about the radiators and or tanks. The connections are all pretty small (3/4") so the tubing will be small so not a whole lot of volume in the tubes. More is better obviously.
2. Pumps. Yes I'll be pumping the fluid. The motor calls for 8 liters per minute flow, and a max of 130F inlet temps (windings need to keep below 347F). The inverter calls for 13-16 liters per minute and the same max 130F inlet temps.
3. Fans. Yes, the idea is to have fans (or the option of adding them) and run them when the temps demand it.
4. Thermal cooling needed. Well, this is where it gets sticky. I don't know how many amps my motor will pull under load since I don't know the efficiency of the truck until I get it running. What little I know so far is that a VW thing has this motor in it (with a gearbox) and when they had a single circuit, it stayed cool enough until they came off the highway after a while. It seemed like the system couldn't pull residual heat out of the motor even though it wasn't really generating any heat, now lacking air flow perhaps, or not enough coolant volume or ??. The main issue was the inverter temps got too high and it went into limp home mode which is interesting since the ratings imply it can live at the motor temps - so he must have been pushing it on the motor too.
As I was writing this and looking up info, I saw something I hadn't seen before, which is a "kit" sold but the folks I got the motor from who have the only working systems using this motor that I know of (described above), so I assume this would meet the need (but it's a bit tall for my application). But it puts me in the ballpark for size.
http://store.evtv.me/proddetail.php?...CIRCUIT&cat=11
http://www.speedwaymotors.com/Derale...ler,53659.html
It did occur to me that I could mount it at an angle, but would prefer not to for various reasons. But this gives me more ideas to look at - existing dual circuit offerings.
Anyhow, I make some time a little later to check out the links and do some more searching, thanks!
Old December 9th, 2014, 07:50 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Measured best I could and it looks just a little off what you are looking for
13" or 13 1/2 tall at the high point (rad has a slope of an inch or more from one side to the other on the top so one side is around ~12 tall)
7" wide
2008 + Kawasaki KLR650
Old December 9th, 2014, 07:52 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Pics
ID:	108350   Click image for larger version
radiator
Small Car Advice Flagg Misc. Chit-Chat 6 January 13th, 2010 09:18 AM
looking for small tool suggestions Emerson00 Defender Technical Discussions 5 December 1st, 2008 07:02 PM
sw small rear windows mattdh Defender Technical Discussions 1 July 5th, 2004 05:05 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
galv. small parts mattdh Defender Technical Discussions 0 November 20th, 2003 08:31 PM
