Sintered brake pads. - Defender Source
Old April 21st, 2015, 05:29 PM
I was thinking about this and on my motorbikes I used to run EBC sintered pads. They were frankly amazing ... Rear wheel off the ground at 130mph type amazing. The sintering also made them super effective in the wet. Do sintered pads exist for cars?
Old April 21st, 2015, 05:54 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
Yes, some of the Lotus crowd rave over Carbon Lorraine sintered pads. I've never tried them.
Quick look at the on line catalog lists their pads for a Hummer(!) but oddly not Land Rover... and CL is a Euro company.
I like EBC's pads on my little Brit cars..
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old April 21st, 2015, 06:53 PM
Building your own ghetto twisted drift Rover? WWHD? -Jeff
Just curious was wondering if it would make a decent upgrade for not a lot of investment.
My chrome spinners, whale foreskin seats and gold wrap are in storage ready to do my WWHD build. That won't need a brake upgrade as it's only cosmetics.
Old April 21st, 2015, 07:29 PM
You'll definitely want to powder coat your rusty frame on that build.
Old April 21st, 2015, 09:07 PM
Do I have to remove the rust first?
Old April 21st, 2015, 10:05 PM
It should be fine under all the waxoyl
Old April 22nd, 2015, 04:40 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
While it's probably not relevant since you'll never get the temps but sintered pads run hotter and increase the potential for damage to rotors. Not really an issue on a bike but on a 2 tonish truck with non vented discs.. also, I think our rotors are cast iron and I believe sintered is mainly designed for stainless steel. probably no big deal but changing rotors on a Defender is such bitch I want them to last as long as possible. Besides, the pad is the least of my stopping distance problem.
Old April 23rd, 2015, 12:49 AM
On a defender I think it's a waste.. Normally those pads are a harder compound then stock and need more heat to work well..
Actually on the d90 I would go with a softer compound (ie stock) and make sure the brake booster is up to snuff
I can pagid oranges for road courses and stock for autoX when I had my 964 cup... Stock b/c they would heat good and grip, oranges would squeal until hot..
Rotors were drilled on the cup, then carbon with gt3 brakes.. Biggest improvement in autoX are dampers.. (Moton)..
95' D90 - daily driver..
Genuine Rear Brake Pads for Sale oldscratchggf For Sale - Parts 2 July 12th, 2006 03:13 AM
brake discs and pads blenkush Defender Technical Discussions 3 January 23rd, 2005 01:32 AM
Ceramic Brake Pads Peter Defender Technical Discussions 7 November 12th, 2004 02:45 PM
Brake Pads ??? Vadim Defender Technical Discussions 3 September 29th, 2004 04:24 AM
About to change brake pads whitelandy33 Defender Technical Discussions 13 December 19th, 2003 01:57 PM
