Shop Heaters: Propane or Kerosene? - Defender Source
Old December 18th, 2011, 05:46 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Looking at those construction site style heaters. Propane or Kerosene? Which one one is most likely to kill me from CO2 poisoning?
Semper Fi!
Old December 18th, 2011, 06:04 PM
Propane is easier to deal with, but boy do those things suck down fuel. Very expensive way to heat.
I have a Kero/diesel one and I get a days worth of heat from a tank. I think it's a ten gallon set tank. That's almost $50!
Old December 18th, 2011, 06:36 PM
Wolf Fabrication
Sterling Archer
'08 D3
Problem is I can't use electricity, and can't run gas out to the garage, so I am stuck with some sort of mobile solution. I've never bought kerosene, but I'd think it would be more economical solution.
Semper Fi!
Old December 18th, 2011, 06:37 PM
I have a propane, think its 50,000 btu, and a propane bottle lasts 14hrs. I installed a wood stove and put a fan behind it last month. Realize thats not an option for most but it warms my drafty 1700 sq foot shop up fast and keeps it very comfortable.
either propane or kerosense heaters need elecrtic for the blower motor to be of any real use.
Old December 18th, 2011, 08:21 PM
phoenix37's Avatar
phoenix37
john
Ive tried Kerosene and it sucks. It gave me the worst headaches. Literally wasnt able to work more than an hour or so before I had to stop. Maybe its just me but the fumes from the kerosene were terrible.
Old December 18th, 2011, 08:23 PM
Wolf Fabrication
Sterling Archer
'08 D3
True...
Semper Fi!
Old December 18th, 2011, 08:37 PM
dchapman
Daniel Chapman
1999 D1
A garage with no electricity?
Old December 18th, 2011, 08:53 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yes.
Semper Fi!
Old December 18th, 2011, 09:44 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Hey Angel eyes,
If you haven't got any power, and you don't mind pokin' a hole in your roof, a double barrel wood stove is pretty hard to beat. Harbor freight or Northern hydraulics will have the parts. Kerosene will give you a hell of a headache. Propane and kerosene really oughtta be vented...
And remember...If you're going to shoot, shoot, don't talk.
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old December 18th, 2011, 09:57 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Go with a universal Oil Burner and get the tax write off! These things will burn all types of fluids and grease!
Old December 19th, 2011, 12:09 AM
dchapman
Daniel Chapman
1999 D1
Isn't a garage with no electricity called a shed?
And they're dirty as shit and the burners always clog up. You spend more time working on them than using them.
Old December 19th, 2011, 06:22 AM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks. My post wasn't to debate perceived garage/shop/shed/outhouse naming conventions, it was to ask about differences in heaters.
If I actually owned the garage I would have power and gas running to it, but Uncle Sam owns it.
Semper Fi!
Old December 19th, 2011, 07:51 AM
LRover's Avatar
LRover
J. Michael McCaig
If you are just tring to stay warm while you are working on something then I think propane radiant heat is probably your best option. Keeps you warm without having to heat the whole space and there is nothing to install.
Old December 19th, 2011, 07:56 AM
Wolf Fabrication
Sterling Archer
'08 D3
I know, but the radiant ones only heat a small area and I'm trying to heat a larger area. Plus, since these heaters create a lot of CO, I want something I can put near a fresh air source and blow in to the garage without killing me. I've used the small radiant heaters before, but I end up with a CO headache after an hour or so.
Semper Fi!
Old December 19th, 2011, 09:18 AM
add a small generator to the equation ?
Old December 19th, 2011, 09:47 AM
Wolf Fabrication
Sterling Archer
'08 D3
My new shop sucks right now. I have to run 220v and 110v extension cords from the house to get anything done. The one 20amp electrical outlet in the garage is also tied to stuff in the house. I can't even power up the compressor without the lights flickering. Gotta love military housing....
Semper Fi!
Old December 19th, 2011, 10:51 AM
I use a propane radiant style one that mounts on top of the tank. Works well. No measured CO (get a detector...) and is quiet. They do eat the oxygen over time, so some ventilation is needed.
Not sure what Bill is on about it being more expensive??? Propane is not normally more expensive than Kero or Diesel.
edit: one if these: http://www.mrheater.com/product.aspx?catid=42&id=119 Lots of heat for a two car garage and it adjusts down.
Old December 19th, 2011, 11:15 AM
Wolf Fabrication
Sterling Archer
'08 D3
I have a two burner one of those, but was hoping for a little more heat. I think I am going propane anyway, but maybe try to find something between the monster heaters and the tank-top heaters.
Semper Fi!
Old December 19th, 2011, 11:29 AM
dchapman
Daniel Chapman
1999 D1
Think I'd do something like this, and just run it off a 20lb propane tank.
http://www.amazon.com/Mr-Heater-MH20.../dp/B0000C6E39
Old December 19th, 2011, 11:31 AM
Wolf Fabrication
Sterling Archer
'08 D3
Wow, that's actually a cool heater. I like the BTU output too.
Semper Fi!
heater
Anybody know of a good shop in Cali ? skibigwest Defender Technical Discussions 2 February 13th, 2006 11:54 PM
Need RECO on shop in Long Beach area reaper99999 Defender Technical Discussions 2 February 6th, 2006 10:24 AM
Shop Moving Sale Roadsiderob The Vendors Loft 2 October 13th, 2005 04:13 PM
The Greatest Rover Shop Ever Buckon37s Misc. Chit-Chat 2 December 22nd, 2004 01:00 PM
So. Cal. Brake shop?? benh Defender Technical Discussions 2 December 3rd, 2003 01:53 PM
