Shock tower trouble - Defender Source
Old March 15th, 2010, 01:34 PM
Shock tower trouble
Pothole 1, LR 0
Did manage to weld it all up and it should be fine. There were a few cracks in the top layer but the cup shaped bit underneath was solid so I just welded up the cracks and ground it all back down. No wonder it handled like ***t
ID:	25763   Click image for larger version
ID:	25765   Click image for larger version
Old March 15th, 2010, 01:37 PM
Your shocks are too long or you do not have bump stops. That should never happen.
Old March 15th, 2010, 02:03 PM
In the past have had shocks that were too long on other vehicles. It is possible that the Monroe's I took off were too long. BUT...I think this was due to a pre-existing problem of corrosion in the upper plate. The rest of the tower is ok but it is one I pulled off and cleaned up last year so there was some rust. I didn't bother to measure the old shocks since I was removing them. But yeah , possible that they were too long. But again I think fatigue followed by a massive hit from an impressive DC pothole. I thought we would have a flat for sure. Bumpstops ok and in place. Well, now replaced with fancy red ones.
Old March 15th, 2010, 03:18 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
The way the top seperated, makes you wonder about being a defective part. Nice work. Curious what the other side looks like? Mark
Old March 15th, 2010, 03:35 PM
oilburner's Avatar
oilburner
JL
large pile of parts
The original weld looks way narrow and crappy. Likely a monday morning hangover welding job at the factory.
JL
Old March 15th, 2010, 05:22 PM
not sure which original weld you mean? BTW after looking at this, I think the way they are made is that there are two cups back to back the top one is welded open side up around the upper perimeter and the lower one maybe spot welded the upper one, open side down. Does that make sense?
The other side looked fine, was a much newer tower from the looks of things.
Old March 15th, 2010, 05:34 PM
glad you fixed it. we almost died when we hit that expansion joint !
Old March 15th, 2010, 05:49 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Got a nice dent in the hood now? Or didn't it push up that far?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 15th, 2010, 06:40 PM
too true. changing lanes unexpectedly is always rather fun. Glad someone was in the car with me as proof I am not exaggerating.
Dan, the shock never went all the way through. It was as shown in the first picture, just plain broke off. The lower cup prevented it from going any higher.
Old March 15th, 2010, 06:43 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I've seen it before with stock shocks. Crud can build up in that upper cup and rot can be bad.
I just picked up a set of stock length tubular turrets for this very reason (and you can grab the top which is sooo much better when changing them)
Old March 16th, 2010, 12:20 AM
Roving Beetle
Doug
My recently "new to me" (and now since sold after a week of ownership) 1996 D1 had that happen at this years Winter Romp. Clunked all the way home.
Welded up and good as new.
And it would take a lot to get it to come *up* through because of the underside cup Dave mentioned.
Doug
Old March 22nd, 2010, 05:58 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Had that happen on some crappy aftermarket turrets. Wimpy spot welds and the turret top pulled out on droop not compression, luckily not pulling out the brake lines in the process, I don't think there's enough travel available with standard suspension bushes. Welded them up properly and they've been fine since.
By welding up I mean cutting a slot in the outer and welding through to the top disc.
Mike Hammond
90/110 Front Shock Tower Cover Thingamajigies Wolf Fabrication Wanted 9 May 18th, 2011 11:16 AM
Shock & Tower Choice ajh Defender Technical Discussions 8 May 15th, 2009 11:19 AM
Loop mount front shock tower? cellulararrest Defender Technical Discussions 19 March 17th, 2008 09:20 AM
Rubberized Spring Isolators/ Shock Tower Securing Ring? oldscratchggf Defender Technical Discussions 10 October 2nd, 2006 05:44 PM
Fitted Rubber Shock Tower Retainers wicks Misc. Chit-Chat 21 March 28th, 2004 10:51 AM
