She died! - Defender Source
Old December 24th, 2004, 04:20 PM
rustydefender
Russell Newton
97 D-90 sw
Talking She died! but now she lives! hooray!
My defender died. I was driving along and the engine felt weak and died! I pulled over and it just wouldn't start again. Fortunately I was only a few hundred yards away from my house an I was able to get a buddy and my JEEP to tow it back home it was terrible. I believe the problem has to do with fuel delivery, she turns over just fine and will even run for a second or two. It seems like it isn't getting gas, maybe a fuel pump problem. Damn bad luck I've had the same engine in my 97 rangie, never a single engine problem. I hope it's a dead fuel pump not something worse.
Old December 24th, 2004, 06:58 PM
Just disconnect a fuel line and turn the ignition. If it sprays, then the fuel pump is good. I mean, be careful and stuff...
Old December 24th, 2004, 08:32 PM
something clogged maybe, good call on the fuel line you can disconect it on the passenger side frame from the fuel filter. you can check the fuel pressure too on the fuel rail. any codes from the OBDII? sorry to hear about your loss.
Old December 24th, 2004, 08:52 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
Russ: Sorry to hear this. Especially on Christmas Eve
Check the fuel pump (especially if you had been driving for a long period of time - they tend to crap out after long drives, getting too hot, or in high altitude), also look at the fuel filter. CEL as mentioned by Phil or maybe a sensor??
Best of wishes,
RoverChic
I bought the diamonds myself so I would not have to say thank you to anyone.
Old December 24th, 2004, 09:19 PM
Russell, a good and safer way of checking pressure on 97s is to hook a pressure gauge on the fuel rail, there is a nipple on the rail on the passenger side fuel rail between the 2 inner cylinders, and it should have a black cap on it. I believe you should see something in the 30 to 40 psi range.
I am not saying that it is terribly bad to pull the line off to check pressure; the manual kinda says to do it that way to depressurize the system. But my bet is the fuel filter! Why because it is cheap and easy! Good luck and happy holidays!
Old January 5th, 2005, 08:24 PM
rustydefender
Russell Newton
97 D-90 sw
She lives once more. It turns out the ecu got wet when I hosed it off. At least that is what I figured when I got back from vacation I tried to start it again and she runs great. My mechanic told me a wet ecu was the culprit. However i am dissapointed that the d-90, the supreme safari tested machine can't take a soft shower with a garden hose! Any suggestions to waterproof the ecu?
MY 90 has died mikeslandrover Defender Technical Discussions 29 May 19th, 2011 04:18 PM
Clutch Died John_Karlsson Defender Technical Discussions 10 August 24th, 2009 06:35 PM
300tdi died won't restart discotdi Defender Technical Discussions 2 August 3rd, 2009 10:17 PM
110 Died - Your Thoughts? 3rovers Defender Technical Discussions 2 February 10th, 2008 12:48 AM
Bouncing Odometer - Finally Died wicks Defender Technical Discussions 22 November 7th, 2006 07:13 PM
