Sell, fix, or find help - Page 2 - Defender Source
Old July 29th, 2014, 03:33 PM
Great advice except for Cityside Garage.
Old July 29th, 2014, 03:45 PM
byrne, pm me if you need to a set up a time for me to stop by for a day to assist. Like ron says, this is not difficult work. The worst part is the fear of the unknown.
I'd also plan on a new ignition switch, glow plug relay and who knows what else.
To clarify what we are discussing. Is this a stock ex-MOD, 2.5NA truck? if so, there is no glow plug relay. It is straight power from the ignition switch to the glow plugs.
The engine harness is 4 or 5 wires. It is all pretty simple. If he buys a normal civilian defender harness, it will be different and a few changes will be needed, all fairly simple.
I would first step back and talk about what went wrong and why. You don't want to put in a new harness to find out the short came from outside the harness and fries the new one.
Maybe some pictures of where it burned. If you can follow the wire(s) that were the cause, we could help locate the source of the problem.
Old July 29th, 2014, 04:17 PM
The Dro
Dro
1988 Ninety
Ed, I spoke with Conor. We can go together.
Most likely the wire insulation was bad from its age.
Autosparks has a harness for the 2.5NA diesel.
Old July 29th, 2014, 04:23 PM
I'm talking about the main harness being different for an MOD and civilian truck. The engine harness is 4 or 5 wires and could be replaced manually in a hour.
Old July 29th, 2014, 05:35 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
If you, Pedro, and whoever else wants to stop by and help me do it I'd really appreciate that as I told Pedro, I'm very willing to compensate on this.
I emailed Autosparks with the info on my truck (110 Ex-MOD FFR, 2.5 N/A Diesel) and asked for quotes etc. Would it be worth my time to have them wire in extras like connections for 12v chargers, radio, fog lights, etc or should that just be done here?
Thanks again guys, this is turning out to be a good project.
Old July 29th, 2014, 05:49 PM
Extra connections, depends on the cost and what you want. At the worst, you leave them dangling for connection at a later time. I have no idea how Autosparks handles custom looms and fuse boxes, or how they know what wires to run and how long they have to be. DIY sounds like it would be a challenge for you to do alone so maybe better to have them do it for you if not too expensive - only you can evaluate that.
Old July 29th, 2014, 07:02 PM
The Dro
Dro
1988 Ninety
Conor
Let us know when the harness gets here so Ed and I can coordinate.
I have a few crimping tools, bits and bobs I can bring just in case.
As for the compensation... motha trucka please. Just pay it forward.
But please have plenty of cold Coca Cola.
Old July 29th, 2014, 07:04 PM
I feel special for being able to ride with the Dro.
Old July 29th, 2014, 07:11 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
Haha sounds good guys. All beverages and meals on the house.
Old July 29th, 2014, 07:15 PM
The Dro
Dro
1988 Ninety
I like my Filet mignon medium well.
Old July 29th, 2014, 07:22 PM
the rover shop
shayne young
I was going to offer my services....until I saw who was going already...
Old July 29th, 2014, 07:28 PM
Should take a couple weeks to get it. No don't pop for the extras. I have a TON of wiring stuff.
Old July 29th, 2014, 07:34 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
For what its worth i built my own engine harness in about an hour. Less than 20 bucks in materials. I had no idea what i was doing and it came out fine.
Unknown Author
716-898-8153
Old July 29th, 2014, 07:38 PM
Ignotus
gene
1960 109, w/200TDI
2 ways of doing it. 1 is to buy the recommended autosparks loom and when you remove a section replace it with the right section. The other way is to buy all the correct wire and run it all yourself. Either way you can add any extra lights or power outlets you wish to do.
You will need a good wiring diagram in for both. This way you will know your electric system for when you are in the outback and something goes wrong.
The British have a vehicle wiring colour code so it's fairly easy as all Brit cars will have, let's say for the right indicator a green main with a white tracer. Left hand is green/red. Simples!
The hard bit is taking out the old and if burned figuring out what it went to. Label everything before you take it off.
HTH Good luck!
Gene
1960 109
1960 88 Ignotus
Blog;
Old July 29th, 2014, 07:59 PM
The Dro
Dro
1988 Ninety
HTH Good luck!
No guts no glory... I vote to get the Klein tool and cut that biotch up
Old July 31st, 2014, 01:06 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
I'm trying to order the harnesses from Auto Sparks but they want to know the amperage of my alternator- To me it is just a regular alternator but I'm not around my truck. The big FFR generator was taken out before I owned it. How can I tell? It's sitting in a shop still and they said the only way they could find out was for them to test it, adding to the cost...
Old July 31st, 2014, 01:26 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
forgot to ask, is there anyway of looking at it and being able to tell?
Old July 31st, 2014, 02:09 PM
Post a picture.
Old July 31st, 2014, 06:20 PM
Just pick one with a higher rating. No harm if yours is lower and if you ever want more amps, the wiring will be ready.
Originally Posted by pendy
I'm here for the D's
to sell or not to sell That's the question bar11 Misc. Chit-Chat 47 February 6th, 2014 12:13 PM
How shopping carts can help fix your NAS110 Neil McCauley Misc. Chit-Chat 19 October 21st, 2009 09:26 PM
