SD Rack Feet - Defender Source
Old October 1st, 2010, 01:52 PM
bjf's Avatar
bjf
barry f
94 ST #395
SD Rack Feet
So I have some SD cross bars I want to use on my 90 and the feet are destroyed. I think Mike said they will not sell the feet to the SD racks they are making so I asked my guy making the screens if he could copy them. He said he could but not worth the trouble unless he makes 16 sets. Something about the metal bar he has to buy to do it. So the cost is roughly $475 a set. I want one so in order to do this 15 other people need to want them.
Now I have no idea if anyone else wants them and I might be wrong and Mike might be selling them in which case obviously he is the guy to go to but if not and the interest is there I could have them done.
Let me know.
thanks
ID:	31788   Click image for larger version
Old October 6th, 2012, 10:46 AM
cptlsc
scott cunningham
1995 D-90
Did you ever come up with a soloution to the SD feet?
Old October 6th, 2012, 12:30 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ecr made replacements.
Old October 6th, 2012, 12:35 PM
Rommel's Avatar
Rommel
Rolf
94/95/97 Many
Feet
For $475.00 ?
Old October 6th, 2012, 01:46 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
If someone can send me an SD foot I can engineer a solution.
Semper Fi!
Old October 6th, 2012, 03:04 PM
Grover's Avatar
Grover
Are these made from solid aluminum and machined to size?
Old October 6th, 2012, 03:42 PM
cptlsc
scott cunningham
1995 D-90
ECR had these for $65 each and it keeps the crossbars factory. They are out of stock and do not know when or if they will be making them again. Same with their oil line converson kit. If anyone has one of the feet from ECR maybe Wolf can duplicate them for a reasonable price.
Old October 6th, 2012, 03:56 PM
Search oil cooler lines. ECR isn't the only supplier of them.
Old October 6th, 2012, 04:51 PM
Almost identical to my Thule feet
Old October 6th, 2012, 04:59 PM
Wolf Fabrication
Sterling Archer
'08 D3
Looking at the feet, my cost in materials alone would be about $40 each. I could probably hit the $65-$70 each price point when done.
Semper Fi!
Old October 7th, 2012, 09:17 AM
Looks like a bit of tube cut in half, bit of box welded on top, some holes drilled, tapped and powder coated.
I would imagine the labor represents the largest cost in making these.
Old October 7th, 2012, 10:38 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Wolf I may send you some feet I have laying around. The stock ones suck with the hinge design. I think you can come up with a better design. As you probably know it get tight on the inside next to the roofline on hardtops... or at least on my POE top it does.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old October 7th, 2012, 11:08 AM
Wolf Fabrication
Sterling Archer
'08 D3
Send me an email or PM and we'll work something out!
Semper Fi!
ac, rack
SD style rack feet available in Sept. ECR The Vendors Loft 17 September 13th, 2014 12:46 PM
Sneak peek at new SD rack ECR The Vendors Loft 16 August 22nd, 2010 10:23 AM
Badger surry and an SD rack bharris Defender Technical Discussions 6 June 9th, 2009 01:53 AM
Feet for Thule bars or SD rack front bars evilfij Wanted 5 April 4th, 2009 12:49 PM
Custom Rovers North D90 Roof Rack Barnett Childress For Sale - Parts 0 October 9th, 2005 07:29 AM
