Screaming O2 sensor deal! - Defender Source
Old February 27th, 2009, 07:23 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Ok, I can't guarantee I have the cross reference right, but I am sure enough and the price is low enough that I just ordered a pair.
According to the D-90.com FAQ, Nissan part number 22690-61A00 will work by splicing in your existing connector.
This website cross-references the Nissan # to Standard SG-130.
http://bbb-carb.com/std/oem-nissan/oxygen-sensors.htm
RockAuto.com has them on clearance right now for $27
But as of this post there are only 6 left.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 27th, 2009, 11:52 AM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
is that the 97 as well?
Old February 27th, 2009, 02:34 PM
Hans's Avatar
Hans
Hans Haase
No, definitely not for the '97
-Hans
My oil line fix
Old March 4th, 2009, 01:56 PM
Hans's Avatar
Hans
Hans Haase
Parts arrived today. Stamped "Nissan" on the sensor, which is a good sign. Also has the correct wire colors, nose profile and appears to be the correct thread. Since 12mm thread is only one type of sensor, I'm feeling more confident now. Will install tomorrow.
And just to confirm, I believe this sensor would be correct for all the 3.9 engines running the 14CUX hot-wire ECU and 3-wire sensors.
-Hans
My oil line fix
Old March 4th, 2009, 02:03 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Work on 4.2 as well. I have used them with great success, got them from local Napa. Make sure you put shrink tube on the solder points when you attach the old connector.
Old March 4th, 2009, 02:48 PM
wish I'd known about this back in october....oh well, soon there will no longer be any O2 sensors in my fleet...
-Hans
sensor
110 Kills Multiple O2 Sensors pcscharfe Defender Technical Discussions 8 May 20th, 2009 10:19 AM
O2 Sensor Removal w/ LRT-12-047 pcscharfe Defender Technical Discussions 9 November 13th, 2008 12:30 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
Anyone shear an O2 Sensor Ragland Defender Technical Discussions 2 May 24th, 2004 08:37 PM
O2 sensors J4hand Defender Technical Discussions 0 January 8th, 2004 02:39 PM
