Sand Ladder mounts? - Defender Source
Old July 25th, 2004, 10:47 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Sand Ladder mounts?
Anyone know who carries a set of sand ladder mounts (that hopefully fit a 97 90 rack)?
Old July 26th, 2004, 11:20 PM
nickt's Avatar
nickt
Nick Taylor
1998 Ex-Camel Trophy 110
I got mine from Mantec, to fit a Brownchurch rack.
http://www.mantec.co.uk/index.cfm?pa...ail.cfm&id=951
From memory, I think it'd be difficult to modify them to fit the NAS rack.
Cheers,
Nick.
Old July 28th, 2004, 04:45 AM
Kev Baldwin
Kevin Baldwin
2.4 Tdci 110 Utilty Wagon
FYI. The sand track mounts used on all Camel's as supplied by Mantec, are nothing more than lengths of threaded bar and wing nuts. The circular plates used to secure the sand track to the rack are in fact, the metal discs supplied by the factory to secure Classic Range Rover spare wheels in place in the back of the vehicle.
As has already been said, it would be difficult to mount them to the roll cage, as the threaded bar goes through the flat square section of the Camel racks. Short of drilling a hole in your cage, it looks like you're looking at fabricating something to clamp onto the cage.
Kev
Old July 28th, 2004, 10:54 AM
XD90's Avatar
XD90
James Morgan
1986 Ex MOD XD90
hi
i owuld have thought you could use scaffolding clamps onto the cage
whack them on get a large wingnut that will fit on the threaded end that sticks out slide the sand ladders on get a large washer<plate of steel /aluminum> about 8 inch in diamiter with the correct size hole in the center
saying that i dont know if you have scaffolding clamps over there the same as we do here but here they are very cheap and should be pretty much the right size for a roll cage i did this on my old SIIA trialer with a saftey devices roll cage
if you get stuck sourcing clamps in the US gimmie a shout and ill send ya a couple over
James
just done a quick search this is the kinda thing i was thinking about
http://www.crocodilescaffolding.co.u...php#DualClamps
take a look at the HALF SWIVEL COUPLER there is a clicky on the poage too with the dimensions
i was thinking if you clamped that onto your cage (using a locking nut rather than the standard nut supplied with it) then you could get a bolt thru the hole at the side of whatever length would suit you (depends on how many sndladders you carry) then just pop the aluminum / steel washer you made and a large wingnut of the right size youd be away and laughing
James
Old July 29th, 2004, 04:16 AM
wicks's Avatar
wicks
Wicks
Interesting. Thanks for the feedback guys. Who else sells Mantec around besides RA? Sent them an enquiry and got back an informative "no we don't". Might just modify Mantec kit to suit. Perhaps mounting to a HALF SWIVEL COUPLER.
mount
Engine Mounts david_jackson Defender Technical Discussions 1 February 8th, 2006 06:48 PM
ARB Hi-Lift Mounts Dfndr90 Defender Technical Discussions 4 September 1st, 2005 03:43 PM
Installing engine mounts Doug Defender Technical Discussions 4 February 23rd, 2005 06:49 PM
weld on motor mounts pendy For Sale - Parts 3 September 8th, 2004 03:10 AM
Busy Weekend d90 highlift mounts and OT content dnewman9 Misc. Chit-Chat 4 July 13th, 2004 11:55 AM
