sand ladder lock? - Defender Source
Old October 7th, 2015, 09:31 PM
Ignotus
gene
1960 109, w/200TDI
sand ladder lock?
How do you secure your sand/bridging ladder from theft while on the road? Pics?
Gene
1960 109
1960 88 Ignotus
Blog;
Old October 7th, 2015, 09:46 PM
You need a Sandblechhalter
GMB-MOUNT.de
its nice stuff btw.. and you can use you Sandblechhalter as a table on the side!! when properly equipped with the Klapphalter
Or you could use a home made version and a lock but having a Sandblechhalter just sounds better.
ymmv
95' D90 - daily driver..
Old October 8th, 2015, 07:35 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Cable lock?
Old October 8th, 2015, 09:25 AM
How do you have them mounted? If they are mounted on some kind of stud, you could just drill a hole through it and put a small lock on it.
Old October 8th, 2015, 10:16 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
This is what I use and it's most excellent! I bought mine from muduk but it doesn't look like they carry it anymore.
Land Rover Defender Sand Ladder Bracket
Old October 8th, 2015, 01:05 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
I used the ax and shovel mount sold by Baja Racks. Worked just fine to clamp two MOD PSP type sand ladders to the side of my rack.
Old October 8th, 2015, 01:17 PM
Pretty bad ass and it turns into a table.
Old October 8th, 2015, 09:03 PM
Ignotus
gene
1960 109, w/200TDI
I've been working on some brackets to locate the ladders over the windows for added theft/ingress protection. I like the hinge idea but don't think I need it.
Over the last couple of days I've bent steel, drilled holes, made pins, drilled holes and am about ready to drill the roofsides( I hate putting in more holes!)
ID:	131851   Click image for larger version
ID:	131853   Click image for larger version
Gene
1960 109
1960 88 Ignotus
Blog;
Old October 8th, 2015, 10:30 PM
Ignotus
gene
1960 109, w/200TDI
I've looked into that. I don't think the bottom can be free it needs to be held. There is enough room under the tub capping to slip some steel(flat J hook) and if a good tensioner could be devised it could hook the drip rail and the tub capping with no holes drilled. Maybe some thing like the flat steel with threaded rod welded on and a threaded connector. That would have to be hidden behind the sand ladder to prevent theft. If my thought process is correct the threaded rod would have to be left and right hand bits. Similar to a turnbuckle.
Gene
1960 109
1960 88 Ignotus
Blog;
Old October 9th, 2015, 09:43 PM
Ignotus
gene
1960 109, w/200TDI
Heffe,
Are you thinking this;
Gene
1960 109
1960 88 Ignotus
Blog;
Old October 9th, 2015, 09:50 PM
i'm still going with the Sandblechhalter, once you get on the road you'll be going "damn i wish i had a table, Right Here!!"
Old October 9th, 2015, 09:58 PM
Heffe,
Nice! Anything that circumvents drilling new holes is always better.
Old October 9th, 2015, 10:51 PM
Ignotus
gene
1960 109, w/200TDI
then you will be SOL cause you didn't get the Klapphalter!
Gene
1960 109
1960 88 Ignotus
Blog;
110 rear ladder, or ladder for Safety Devices D90 Cage mfj20th Wanted 17 March 2nd, 2010 10:41 PM
D90 Sand Surfing DiscoDino Defender Technical Discussions 0 August 7th, 2005 05:14 PM
Sand ladders Rover- Girl Defender Technical Discussions 9 June 28th, 2005 12:39 AM
Sand Ladder mounts? wicks Misc. Chit-Chat 4 July 29th, 2004 04:16 AM
Aluminum Mud/Sand Ladders C-Delta For Sale - Parts 5 July 12th, 2004 11:02 PM
