Salisbury drum length HD shafts and terrafirma new springs - Defender Source
Old August 4th, 2017, 12:46 PM
Naplm00
Matthew
FYI to all people who have Salisbury drum in the rear and are moving to 24 spline heavy duty shafts.
Both Ashcroft and KAM (now owned by frog Island/allmakes/terrafirma) have stopped manufacturing the drum length shafts. It may be possible to piece together parts but as of now no more long length shafts for thick flange/drums.
So if you are moving to disc in the rear, you now have to swap over everything and can't go the cheap route and keep your drum shafts.
On side note, terrafirma is Re-releasing all of its springs made by a new oem in Australia. So new part numbers, look, color and spring rates.
Old August 4th, 2017, 01:00 PM
brdhmltn
Brad
1985 110 2.5NA
So moving to stock salisbury discs setup, there is still an HD shaft option?
This is actually my weekend project for tomorrow. Move from drums to discs. I ordered all the parts to do an as-stock disc setup, no spacers needed.
Old August 4th, 2017, 01:06 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Damn, I guess I will have to order Hi-Tuff axles then (HTE1724/25X). So yes, there is still an HD shaft option, it just costs a little bit more for the shafts.
Old August 4th, 2017, 01:10 PM
Naplm00
Matthew
They you will be fine, as your axle will be like all post 1994 disc brake Sals. You will use disc brake shafts
------ Follow up post added August 4th, 2017 01:12 PM ------
Originally Posted by JohnsD90 View Post
Damn, I guess I will have to order Hi-Tuff axles then (HTE1724/25X). This sucks as I have the earlier sals with a disc brake rear setup, but I guess spending a little extra for Hi-Tuff is better than converting to the new style.
Well that's alot extra. The old Kam shafts could be had for $650 us front and rear all in for Sals and rover
Old August 4th, 2017, 01:25 PM
Naplm00
Matthew
Double edit:
I just got off the phone with Dutchman axles in Oregon. They can make a double spline axle that will fit the Sal's inner and outer in any length. A set starts at five hundred bucks and we need I need to send them a flange and a spider from the inside
So that's another option for people.
Old November 29th, 2017, 03:06 PM
spikemd
Ted
2001 P38, 2006 LR3, 1991 109
Is Bill at GBR making HD axles for Salisbury? $500 is a great price but I will swapping to discs as well.
Old November 29th, 2017, 03:14 PM
I believe he only imports ones for the disc braked axles, but you should ask him.
After this thread was started, Matthew did a group buy. http://www.defendersource.com/forum/...uy-117521.html
Old November 29th, 2017, 03:18 PM
Double edit:
That actually brings up some interesting options. It would let you use any 30 spline Dana 60 differential while staying stock at the hub.
Old November 29th, 2017, 03:57 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I had the inner shafts for my front Salisbury made by Moser. About the same price range.
