Safety devices Cage / P&P Cage - Defender Source
Old April 17th, 2011, 09:50 PM
Rugbier's Avatar
Rugbier
Gustavo
Well , I have to post this as I took so much crap about the P&P Cage , and how much better the Safety Devices is.... blah .. blah..
Today I've replaced the wing on the NAS90, with a SD cage.. well my dear haters, the flimsy POS support that goes inside the wing has no comparison to the P&P
okay ..now .. lets all sing cumbaya *LMAO*
NO SIGNATURE
Old April 17th, 2011, 10:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
Without pics I believe nothng
Old April 17th, 2011, 10:12 PM
Rugbier's Avatar
Rugbier
Gustavo
Pics of what me replacing the wing or the flimsy POS cage stud?
NO SIGNATURE
Old April 17th, 2011, 11:09 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Safety devices became trendy so, for no other reason, it is the best cage ever. Get that straight.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 17th, 2011, 11:13 PM
Rugbier's Avatar
Rugbier
Gustavo
My bad, why in hell would I not want a flimsy support to my cage
NO SIGNATURE
Old April 18th, 2011, 02:58 AM
the safety devices cage is not trendy so much, but it's OEM-ey. It got cache for being the "stock" cage, and it really looks better than all the other ones out there. If you don't understand that aesthetics is the number one concern when cage shopping, then you mist be one of those "hard-core off-roader types."
That being said' I just mostly finished installing a Safety Devices cage this weekend. I've got a couple bits left to do, but it's almost all there. I took pics and will post a thread when i get around to it.
Old April 18th, 2011, 05:15 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I've been trying to figure out what cage to get myself. I'm going to end up with one of these. http://www.whitbread-offroad.co.uk/r...nal.php#switch The SD cage is the best looking, but the price is absurd for what you get. Most will bust nut over it because it is what's on the NAS trucks and for some reason everybody wants to recreate the NAS look kinda like leaving the badge of the back of your BMW so nobody knows you have the cheaper model. My only beef with the PP cage is the 110 rear supports are too close together and looks funny. Both the SD and Whitbread are further apart. I guess that and the price also.
You little rebel, I like you.
Old April 18th, 2011, 06:14 AM
What does the whitbread one cost? My SD cage was 1350 UKP. They all have to be shipped of course.
Old April 18th, 2011, 06:42 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Goose,
I could be wrong, but doesn't the P&P cage sit on the body and not really tie to the frame in most places? And yours doesn't have an internal hoop, right?
The SD fender cage support you are talking about is perfect for where it sits and what it does. It's 1/4 angle that bolts to the outrigger AND three holes going up the A pillar/door jam. I would argue that is actually the strongest point where the cage mounts because it's bolted to the bulkhead and frame.
What does your P&P use at that point?
Semper Fi!
Old April 18th, 2011, 06:52 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
The whitbread one comes in installed at under 1k GBP. Then you can add on your extra desires as far as x-bars, light bar, whatever. Option for an internal rear hoop. The only big differences I see aside from looks is the front fenders go straight thru then bolt to the frame as opposed to having a similar base as the rears and then the entire cage is welded together as opposed to every section sort of unbolting. Where'd you get the cage from? Direct from SD? I was never able to get them to quote me on a cage so I got RBL181 7SSSquoted from Foley installed and it was over 2k GBP +VAT which I could get removed, but still significantly more. Haven't gotten a quote on the external 110 cage, but I imagine it'd cost way more installed. I'm sure the 1350 would be accurate just for parts?
Old April 18th, 2011, 08:06 AM
Rugbier's Avatar
Rugbier
Gustavo
Originally Posted by Wolf Fabrication
Goose,
Nope. All points seat on frame, and yes no internal through the roof hoop
NO SIGNATURE
Old April 18th, 2011, 08:35 AM
I have seen photos of the SD bulkhead outrigger mounting bent. they could be stronger, boxed in would be good. IIRC the PnP one is a rectangular tube that goes straight to the outrigger. Additionally, I have been advised that not all of the SD front legs went to the outrigger, just some of the later ones in the NAS run and the later aftermarket stuff. Of course this is all somewhat anectdotal and some of it based on second or third hand information from people who claim not to be able to remember things very well....
Originally Posted by Wolf Fabrication View Post
Goose,
Old April 18th, 2011, 09:31 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
The Whitbread cages look OK but what is with this Caulk seam on the front. I am leaning towards P&P... It's like they got 90% finished then said "fuck it just put some caulk around it". And what is with that bolt below the intake???
Old April 18th, 2011, 09:50 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Didn't look like caulk to me. Looked like the same sort of edge stripping that you get with a mantec snorkel for discovery's that goes around the edge where you have to cut.
Old April 18th, 2011, 10:24 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
lol.
Have any of you US guys priced out a local fab shop? The prices in US are around 3K. For that, I bet you could get exactly what you wanted made here. The cage design is really lacking from a strenth perspective, so maybe making it out of 4130 would help. Just a thought. I know a few places that would beat 3K.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 18th, 2011, 10:47 AM
tjfslaughter
thomas
Burbon
It's probably a trim lock edge. I just think that all the other points are through bolted. Why didnt they do the same up front. I like the prices but it seems that they cut a corner on this part. I think that is an opportunity for water intrusion.
Old April 18th, 2011, 01:08 PM
@mrgreenspan - yeah, 1350 was just parts. I did the install myself and I could easily see foley charging 700+ quid for the install, it took me almost 20 hours. A shop probably wouldn't take that long, but it was still a labor intensive process.
@ren change - my 95 NAS didnt even have the little attachment brackets for the bulkhead outrigger. The 93 110 had them, I think it's a hit or miss thing.
Ive said it before, i consider a cage to be a one-use item. I don't have one so that i can bang the body against trees, ive got it so i feel better about the integrity of the truck. If it does it's job once, I'm happy. I recognize that buck wants something else from a cage.
Old April 18th, 2011, 01:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
Jim
Did you do it all yourself?
Old April 18th, 2011, 02:14 PM
Wolf Fabrication
Sterling Archer
'08 D3
lol.
Exactly. I've quoted several 110 and 130 cages, and they run about $3500 to fab. I have zero desire to build one as they are very labor intensive. That's why I bought a SD one versus building one.
Semper Fi!
Old April 18th, 2011, 02:20 PM
Originally Posted by bjf View Post
Jim
I did it mostly myself with help at critical points. Its not a one-person job to put the rear hoops on, and extra assistance makes it go a lot faster anyway.
cage, safety devices
NAS 110 Safety Devices cage "parts" FS ECR The Vendors Loft 2 December 3rd, 2009 09:58 AM
Safety Devices Roll Cage JPRO576 For Sale - Parts 10 March 9th, 2009 07:07 PM
Safety Devices Full External Cage Install D-90 JPRO576 Defender Technical Discussions 4 December 18th, 2008 10:32 AM
Safety Devices Roll Cage Source? roverboy Defender Technical Discussions 19 October 21st, 2005 01:20 PM
safety devices ext roll cage jabber Defender Technical Discussions 22 October 15th, 2004 03:22 PM
