Runaway 200tdi - Defender Source
Join the Defender Source Community Today
Old October 22nd, 2014, 10:21 AM
Davis's Avatar
Davis
Chris Davis
94 D90, 88 RRC
Runaway 200tdi
Not sure if this has been previously posted, but I didn't see it. Wish it went to the very end...
Old October 22nd, 2014, 10:38 AM
jafir's Avatar
jafir
Jafir Elkurd
http://www.amot.com/products/air-intake-shutoff-valves
Old October 22nd, 2014, 11:13 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I have thought about using a fuel shutoff (edit: meant to type air shutoff) on the OM617 conversions, but never seriously looked into it.
Thanks for the link.
Lots of good info and options available.
RDavisinVA
Old October 22nd, 2014, 11:19 AM
Originally Posted by rdavisinva View Post
I have thought about using a fuel shutoff on the OM617 conversions, but never seriously looked into it.
It is running on engine oil. A fuel shutoff will not help anything.
Just stall it. The engines are not that powerful.... High gear, drop the clutch.
Old October 22nd, 2014, 11:26 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Mis-typed... thanks I meant air shutoff.
I was working on our lawn mower and had to add a fuel shut-off and have had that term stuck in my head since Saturday.
Yes or drive it like that runaway bus movie only slower going up hills.
Looks like my 300TDI running on a UCO and WVO mix before pulling in front of 2 motorcycles and a convertible.
It was a bitch when you had to backup, well otherwise, the smoke was all behind you.
RDavisinVA
Old October 22nd, 2014, 12:26 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I had this happen on a VW diesel years ago, the oil was way overfilled and I went around a corner very quick. The tach needle was pointing straight down, the cloud of smoke was incredible. I popped the clutch in 5th and it quit.
JL
Old October 22nd, 2014, 01:52 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Interesting...
Both of my Diesels are automatics though...
Rent my
Old October 22nd, 2014, 01:58 PM
87 D110 (Ruby)
Interesting...
then just be sure you have your nike running shoes ....
Old October 22nd, 2014, 02:13 PM
Another poor man's solution is to dump a fire extinguisher into the air intake...it clogs the air filter and causes the motor to cut out. At least maybe for those with automatics.
Old October 22nd, 2014, 02:22 PM
Interesting...
if that 7.3 runs away good luck holding it with the brakes.
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old October 22nd, 2014, 02:25 PM
Piece of wood over the air intake.
Old October 22nd, 2014, 02:43 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I could try that on my LWB, I retained the stock air trumpet.
But the 7.3 Ford intake is not accessible.
And Doug is spot on about the brakes...
Rent my
Old September 26th, 2016, 05:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Bringing this back up after seeing the pics of that red 110 burnt and having the rack on my IP not come out of the start position I've been curious about an air intake shut off valve.
I haven't been able to find much in terms of price. The ones I have found for Cummins are $800!
I wonder if this cable operated jobber would be less:
http://pacbrake.com/valving-solution...ut-off-valves/
Is anyone running an air shut off valve?
Old September 26th, 2016, 05:28 PM
There has to be a cheap-o alternative somewhere!
Could serve as a very easy casual anti-theft deterrent as well.
In truth, even a cheap throttle body from any vehicle could be retrofitted and would be cable ready. The horsepower of the LR diesels is lower than or on par with most of the civics and corollas out there.
Old September 26th, 2016, 05:30 PM
See post #9 for "poor mans alternative" .
Old September 26th, 2016, 05:40 PM
LR Max
Thomason, Max
1973 Series 3 109
Get a engine bay fire extinguishing system out of an old race car. Plumb the extinguishing nozzle into the intake/right at the air filter (or whatever). Then have the emergency switch in the cab. In case of runaway, pull knob. Fill intake with C02.
But really, runaways, especially with newer diesels, are extremely few and far between. Unless one completely ignores their turbo going to crap.
Old September 26th, 2016, 05:57 PM
definitely cheap!
200tdi, tdi
300tdi white smoke after runaway! Surfin' Elvis Defender Technical Discussions 29 January 19th, 2012 04:28 PM
Runaway Diesel 300Tdi Buckon37s Defender Technical Discussions 60 November 16th, 2010 02:36 PM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
200tdi D110 Camel Trophy 65k Eric Siepmann Misc. Chit-Chat 22 May 26th, 2005 05:16 PM
