RTT on SD cage, pics thoughts - Defender Source
Old September 8th, 2015, 10:04 AM
scrubs
henery
1974
Hi, After searching for some pictures and comments for a RTT on a SD cage recently installed have turn up little to nothing.
Currently have a Sankey with RTT but in reality I don't like the trailer setup, will sell if a mounting for RTT can be solved.
Any input or ideas would be nice,
Thank you in advance
Edit; Exmod 110 ;--)
Old September 8th, 2015, 10:20 AM
like this?
Old September 8th, 2015, 10:24 AM
scrubs
henery
1974
Yes,exactly what I'd like instead of the Sankey set up,
Thanks for reply,
I'd really like to understand how it's mounted, DIY or a kit available, like everyone else it won't be permanently mounted
------ Follow up post added September 8th, 2015 09:26 AM ------
That's a nice RTT too, makes ARB look old
Old September 8th, 2015, 04:13 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
If I was setting my truck with the full cage up for a RTT, I would just set it on 2 cross beams and drill accordingly. I would likely run the bolts thru the floor and use lock washers and wing nuts, with a dab of blue locktite
Old September 8th, 2015, 04:59 PM
Most RTT's already have the brackets to install directly onto the cage cross bars. depending on brand, you may need longer bolts. too easy.
Mark Kellgren
KM4BOR
Old September 8th, 2015, 05:00 PM
scrubs
henery
1974
Thank for reply,
Best I've come up with is industrial scaffolding ends n pipes,
Looking for other ideas like yours
Old September 8th, 2015, 05:03 PM
Originally Posted by scrubs View Post
Thank for reply,
Mine is mounted on full length Hannibal, which serves more purposes than just RTT mounting.
If I were you I'd go straight onto the roll cage. Consider that if you mount the RTT on something that is mounting to the cage, you are adding middle-man inches to your center of gravity. 2-3 inches for a cross bar is not insignifcant.
Mark Kellgren
KM4BOR
Old September 8th, 2015, 05:47 PM
On my previous 110, I used collar clamps (look around, they're used for all kinds of stuff) to mount a piece of non-skid MDO. I then drilled this to accept my tent. Gave a nice access platform and also makes it a bit easier to install and remove the tent.
cage, ht
hannibal RTT the rover shop For Sale - Parts 18 June 6th, 2012 12:30 AM
FS: Camping Lab RTT for sale Chaucer For Sale - Parts 10 July 19th, 2011 11:41 PM
smoking deal on a Howling Moon 1.4 RTT Uncle Douglas The Flea Market 0 July 15th, 2011 10:19 AM
M416 Trailer with ARB Simpson RTT Rugbier For Sale - Parts 2 May 7th, 2011 04:04 PM
RTT in Denver area jaygoss Wanted 0 July 3rd, 2010 01:11 PM
