RRC Tire Sizes - Defender Source
Old May 23rd, 2016, 08:05 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
RRC Tire Sizes
I am sure this has been covered, very confident. If the site would fix the search function to search for more than one word, I would have tons less post count, probably like 36.
Stock 95 RRC. Can't decide if I want to do 2" lift or just leave stock.
If I go the 2" route, what is the best size and fit that produces no rubbing?
If I stay stock, what is the LARGEST size and fit that produces no rubbing?
Pretty sure my current springs are as close to stock air suspension height. Plan is 80% road, 20% trail, no muddin'.
Previous RRC had 245/75/16 BFG's and didn't rub, no lift that I recall.
Don't need tire brand recommendations, I hate the newer BFG all terrains, look like shit with that sidewall action. Undecided on this as of yet.
Thanks in advance!
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old May 23rd, 2016, 08:25 PM
I'm running 265 75 with 2 inch lift. The taller tires ride smoother. i like the stance.
Was my daily and then my daughter took it....
It's in Northern Virginia somewhere.
Old May 23rd, 2016, 08:56 PM
badvibes's Avatar
badvibes
Jeff
1991 RRC
If you want to go 1" more... I did 2" springs with 1" pucks and 255 85 16s. True 33" tires. My truck's a beater/trail rig. But here's a link to what I did and another guy with a RRC that is much nicer than mine but did the same lift and tire size. If you're thinking about it now would be the time if you decide to do springs. But then again I have a 2nd RRC with stock suspension with 245 65s and that works just fine too.
http://www.gunsandrovers.com/showthread.php?t=8062
I meant to add 235 85 16s would work really well with 3" lift and I suspect they would also work with 2" of lift. Your mileage may vary...
Old May 23rd, 2016, 10:49 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Love that stance! Nice truck Uncle D.
Great question! Thanks for asking, Matt. I'd love to know the max too! Here's my +2" coiler on 245/70. They were new when I bought the truck and are obviously too small. I want to go bigger and am simply waiting for them to wear out ;-)
ID:	150135   Click image for larger version
Old May 23rd, 2016, 11:14 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
1993 LWB with 3" lift and 265/75s KM2
Name:	MAR 2015 047.jpg
Rent my
Old May 24th, 2016, 12:22 AM
badvibes's Avatar
badvibes
Jeff
1991 RRC
255 85s with 3" lift. I radiused the front wheel openings but could've gotten away with much less trimming.
Old May 24th, 2016, 07:46 AM
Contractor's Avatar
Contractor
Will
1969 IIA
My picture sucks, but badvibes is right........I have 2" springs and 1" pucks with 255/85 BFG MT's.
I need to put some more miles on it before I decide if they are the "perfect" fit or not. However, I do love a little larger tire on the truck.......taller, not wider.
Old May 24th, 2016, 07:56 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Oldie but goodie article on rangerovers.net.... Range Rover Classic Tire Choices
Old May 24th, 2016, 08:27 AM
With stock air springs you can fit 235-85 16 if you adjust the turn stops a little. I find that they corrected my speedo so that it is dead on now (by GPS) so other sizes would definitely change your gearing in some (probably negative) way.
Old May 24th, 2016, 10:28 AM
toona's Avatar
toona
Toona
1994 D90
Just put on new 245/75 KM2s yesterday. No rubbing -- I have coil conversion w/ no lift so stock height, but definitely could not go any larger without a lift, though I am not planning that.
Old May 24th, 2016, 10:31 AM
Originally Posted by toona View Post
Just put on new 245/75 KM2s yesterday. No rubbing or coil conversion w/ no lift so stock height, but definitely could not go any larger without a lift, though I am not planning that.
Photos or it didnt happen,
Old May 24th, 2016, 10:33 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Was my daily and then my daughter took it.... It's in Northern Virginia somewhere.
Maybe you want to look into that further
Old May 24th, 2016, 10:41 AM
toona's Avatar
toona
Toona
1994 D90
Here ya go
Old May 24th, 2016, 10:50 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
That looks great, I am thinking same size 245/75, no lift.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old May 24th, 2016, 10:56 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Really liked 245/75's on my D1 when she had about a 1" OE HD spring setup. Great tire size.
Old May 24th, 2016, 11:10 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I have some 245s that I run occasionally---I dont recall any steering rub.
The 265s will definitely rub the radius arms when turning full lock.
Rent my
Old May 24th, 2016, 12:02 PM
REDrum's Avatar
REDrum
Niall Johnson
1970 Series IIA 88 - Sandstone
On my 95 RRC, I ran 235/85/16 with 2" lift and no rubbing. Angles got a bit wonky and needed diffs shimmed a tad.
Toltec Coffee Team:
'99 UZJ 100 - for glamping and grocery getting
'94 FZJ80 - our Costa Rican coffee mule
'96 FZJ80 - 3XL, racked, shaved and dipped in Raptor coat
'70 Petrol SIIA 88 - a Costa Rican expat now with US citizenship!
'70 Petrol SIIA 88 - for Central America surf & coffee exploration
'56 Petrol S1 86 - a whole new kind of land rover hell...
Old May 24th, 2016, 12:13 PM
I had a classic with 245/75 MT/Rs. Good tread pattern but the size is all wrong for classics and they do rub if you use the car off road. 235-85-16s will properly tuck on steelies and give you an extra inch of ground clearance over the 245's. The 245 was popular for a while with the $1000 beater RRC crowd since they came on jeeps and none of the mall crawler types wanted the stock tires. I'm not a fan of short and fat tires.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 24th, 2016, 01:24 PM
dcproven
David
1977 Series III 88 Santana LR
That is what I have (235/85R16), barely 2 inches lift though, agree on the speedo correction, spot on.
Before rear lift:
After the lift, heavily loaded (HD springs):
Old May 24th, 2016, 11:33 PM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
Is she in McLean? I've seen a similar truck twice in the past month.
I'm running 245s only slight rubbing. There's a good RRC tire size write up on rr.net
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
tire
Bolt sizes for NAS ST rear tire carrier and bits? Rufus Defender Technical Discussions 3 September 5th, 2016 08:58 PM
Tire Sizes NashvilleRedD90 Defender Technical Discussions 2 February 8th, 2005 07:34 PM
Tire Sizes Kimos Defender Technical Discussions 12 December 1st, 2004 11:53 PM
Tires Of Various Sizes rvrsrvc For Sale - Parts 0 November 2nd, 2004 01:17 PM
photo sizes - how to reduce paulb Support & Suggestions 2 November 26th, 2003 05:12 PM
