RRC Load space mat options - Defender Source
Old October 16th, 2017, 02:12 PM
bjp
Brent
1995 D90
Any other options besides weathertech trays? Will a Lr3/4 rubber mat fit?
Old October 16th, 2017, 09:31 PM
bjp
Brent
1995 D90
LR3 LR4 mat, would it fit if i cut it down.
Can anybody with an LR3 or 4 get a measurement. Between the 2 main seam lines on each side.
Old October 16th, 2017, 10:14 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Not sure how fancy you want it but I used a stall mat cut to fit in the back of my 109. Works great and cuts down the noise. It's pretty heavy duty stuff and comes in different thicknesses.
Old October 17th, 2017, 10:54 AM
modernbeat's Avatar
modernbeat
Jason McDaniel
2-Door Diesel RRC
Are there any tan mats available for the RRC that aren't cut-to-fit?
Are 4-door mats compatible with a 2-door?
Jason McDaniel
Old October 17th, 2017, 08:44 PM
bjp
Brent
1995 D90
I can pull up the cargo dimensions of an lr4 but trying to get an accurate measurement of the mat. I know the weather tech mat looks like a good fit but not wild about the lip that goes around the outside. Also thinking of just cutting out the holes for the seat belts but if i remember right these weather tech mats are harder plastic, not sure if it will crack if rolled up.
Old October 18th, 2017, 02:02 PM
Winston-Rover's Avatar
Winston-Rover
Mike Giovannozzi
95 D-90 ST
LR4 mat is about 35-5/8" between the 2 seams.
Old October 18th, 2017, 02:23 PM
Winston-Rover
Mike Giovannozzi
95 D-90 ST
I tried to post a pic of the measurement, but it didn't work
Old October 18th, 2017, 02:30 PM
Winston-Rover
Mike Giovannozzi
95 D-90 ST
trying to post photos again
ID:	314801   Click image for larger version
Old October 18th, 2017, 05:59 PM
bjp
Brent
1995 D90
Thank you.
1995 RRC LS3 plus restore Brewie212 Truck Build-up's & Restores 45 February 14th, 2018 10:16 PM
R380 mat & rear load space mat aosias Wanted 2 April 4th, 2012 06:56 PM
D110 Load Space Mat mattarm Defender Technical Discussions 9 November 21st, 2006 07:48 PM
looking for SW rear load space mat NASD90 Wanted 1 December 13th, 2004 04:51 PM
ST rear load space matt in SW? Seriesman Defender Technical Discussions 6 November 2nd, 2004 12:44 AM
