rr classic owner question - Defender Source
Old March 4th, 2007, 10:13 AM
mattdh's Avatar
mattdh
Matt Hurst
can you fit a 4x8 sheet of plywood in the back? whats the measurements for inside wheel well to wheel well, then over the wheel wells side to side, and from front to back with the back seats down? thanks
Old March 4th, 2007, 11:07 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I do not think you will be able to do that.
SWB or LWB? I have both sitting here and cam measure but I do not think it will fit.
Old March 4th, 2007, 11:41 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
You can slide a sheet in if you leave the upper tail gateup - fold down the back of the rear seat and the plywood will just slide in beside the spare tire - it will stick out over the lower tail gate about two feet (SWB) - you'll get lots of exhaust fumes in the truck and I think three sheets is about the max that will fit.
I bought a $300 utility trailer for this sort of thing - much safer and handier.
Old March 10th, 2007, 03:35 PM
mattdh's Avatar
mattdh
Matt Hurst
can you measure both? thanks!!
Old March 10th, 2007, 05:04 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Where did you find said trailer for $300? I may want one.
"It's not a Jeep"
Old March 10th, 2007, 07:24 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Bought it used from a landscaper that was buying a bigger one. Look at the Equipment Trader - lots of utility trailers in there - new they are usually around $550 - used around $300-$400. Mine has a 5 x 8 bed but I think the ideal size for one would be around 4-1/2' x 9' - that way the wheels would track exactly behind the Rover and it would be easier to load sheet materials without pinching your fingers. I like them because the bed height is only 18" off the ground so it's easier to move heavy stuff.
classic
New D-90 Owner Question - Driveline Wolf Fabrication Defender Technical Discussions 9 October 12th, 2007 04:43 PM
1991 Range Rover Classic, 1 Owner, 54K Miles parkcity4x4classic For Sale - Vehicles 5 August 10th, 2007 01:11 PM
New owner in CO w/ locker question bterpstra Defender Technical Discussions 18 September 15th, 2005 08:59 PM
Two RR Classic 6 CD magazines for stock stereo jack frisch For Sale - Parts 0 February 27th, 2005 02:01 AM
RR Classic Driver's Front seat bottom access door jack frisch For Sale - Parts 0 February 27th, 2005 01:50 AM
