Rover Chrome - Page 2 - Defender Source
Old June 10th, 2016, 10:39 PM
Originally Posted by Frank84 View Post
There's a place in CT about 2 hours from me with a tank that the RRC shell would fit into sideways. I'm definitely considering it - but lots to repair before dipping it.
How do you prep the parts before going to the galvanizer? Do you remove all the undercoating, paint, rust, etc? What about inside the boxed chassis?
My place uses a heated acid tank. I don't clean anything.
Old June 10th, 2016, 11:58 PM
Anybody ever do a RRC or Disco body shell? I'm tired of fixing rust and just want to do it once more and do it right. I know there would be some warping but maybe not too bad. There's a few pictures floating around of people that have done it:
Those pics look like the one Dominic @ LR salvage in Ontario did for Rino Granito(?). (username "tightgroup"on D-web). They did it in pieces and then welded it back together.
I saw Rino some years later and he was not happy with it, they could never get it to seal, lots of problems with body alignment etc. One of the guys at LRM is doing one now where they dipped the whole body all at once. I think with a much better result.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 11th, 2016, 07:45 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
WOW!!! That would be amazing.
Old June 11th, 2016, 10:45 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
A UK outfit's site, lot of galvy bits.
YRM Defender Parts - YRM Metal Solutions
KGH - “Stinky LR diesel” Defender Snob
Old June 11th, 2016, 10:56 AM
Been buying from him since he was operating out his garage in 2008. Used to be you would call and his wife would answer, on the kitchen phone, a true case of a cottage industry business taking off. We started our business's @ the same time. Oddly that corresponded to the first year that 25 yr old defenders could come to the US, and the world went into a global recession.
He makes some truly innovative parts. On a pre 2007 5 door wagon there is a beam that goes under the second row seat box @ the front of a 5 door tub. The factory finish and location in front of the rear tire spray on this part was such that if yours lasted 5 years you were lucky. The factory part has tabs that stick up and through bolt to the seat box. Because of these tabs the only way to replace that beam was to cut one in half and then weld it back together once in place, or lift the tub off the chassis.
By removing the tabs, the yrm part allows you to drill out 6 rivets and remove the small triangle behind the 2nd row door and slide the new beam through and then the tabs bolt onto the beam. A seemingly uber simple solution to what was by then a 50 + year old problem .
http://www.yrm-metal-solutions.co.uk.../Products/053A
Old June 11th, 2016, 12:43 PM
jabber
m j
110
Doug, thanks for the link. Need one of these.
Old June 11th, 2016, 01:23 PM
Frank84
Frank Battersby
95 D90
I like the idea of no prep! The place in CT does an acid dip as well it looks like.
My plan would be to dip it all at once and maybe add some bracing into areas that look like they might warp. I'm sure there will be things to straighten a bit afterward, but I think it should be possible.
'95 Soft Top
'89 Classic Tdi
Old June 12th, 2016, 11:42 AM
That's awesome. It would take a bigger tank than what the place I use has.
Maybe dip the bottom and then the top?
Old June 12th, 2016, 12:13 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
We saw a D2 loving the rover chrome look yesterday...
Rent my
Old August 15th, 2016, 05:27 PM
This one has been sitting outside waiting for her turn......
Old August 15th, 2016, 06:16 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I have only just seen this posting, you don't need a big tank, two door RR Classics are bolted together only welded last of the model year than four doors are welded.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old August 15th, 2016, 09:00 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
First of three trips this month...
Old August 15th, 2016, 09:24 PM
I am glad my term has caught on.
Old August 15th, 2016, 10:43 PM
I think Uncle Douglas gets the credit. He started this thread...
Duncan's galvanizing just north of Boston does big stuff to.
Old August 15th, 2016, 11:03 PM
phoenix37's Avatar
phoenix37
john
Here is one... Maine winters were starting to take their toll so the Beast is being rebuilt... note the body in the background.
Old August 15th, 2016, 11:11 PM
Originally Posted by Rocky View Post
I think Uncle Douglas gets the credit. He started this thread... Duncan's galvanizing just north of Boston does big stuff to.
Term is mine. :-) Although Doug has galvanized way more stuff.
Google it.
That series I needs a galvy bulkhead too.
Old August 15th, 2016, 11:14 PM
phoenix37's Avatar
phoenix37
john
this is what i get when i google rover chrome...
that S1 is going to be just fine don't you worry.
Old August 15th, 2016, 11:47 PM
Evilfij gets full credit, he coined Roverchrome. It resonated with me and I have continued its use.
If you think galvanizing is sexy, welcome to the club, there is no support group.
Old August 16th, 2016, 12:51 AM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
Awesome pics! I'd love to get a galvy 130 frame and start a build!!
Old August 16th, 2016, 04:22 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Yes!
JL
Fresh Rover Chrome lrnasd90 Misc. Chit-Chat 6 March 11th, 2013 02:10 PM
TSL Thornbirds on 16 Land Rover Chrome Wheels GMFett For Sale - Parts 11 March 20th, 2010 09:31 PM
Rover Chrome! evilfij Defender Technical Discussions 11 April 21st, 2009 06:53 PM
Chrome wheels phoenix37 Defender Technical Discussions 7 July 7th, 2008 01:28 AM
19 inch Chrome Range Rover Wheels rvrnut110 For Sale - Parts 1 November 8th, 2005 09:14 PM
» Defender Registry
Bobby
curry
B.O.B.
malaD90
Add your Defender
